587,879 active members*
3,813 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > How to setup/program older analog drives without the original controller?
    Nov 2012
    18
    Question How to setup/program older analog drives without the original controller?
    I have an older mill with analog DC servo drives, the parameters for which were normally setup using the Allen Bradley 8400 MP control, but the control is no longer working, how do I change the settings in the drive if I'm using a different controller?
    Nov 2012
    18
    Question Retrofitting old CNC Mill - Questions
    I'm looking to retrofit an older CNC mill with analog +-10V drives, the existing Allen Bradley controller is no longer functioning and will need to be replaced, can anyone suggest a suitable replacement that can be used to drive +-10V analog drives, as well as suggest how I would be able to tune the drives without the previous controller?
    24220
    Re: Retrofitting old CNC Mill - Questions
    There is Mach or Camsoft using the Galil motion card or Dynomotion with Kanalog.
    What model are the drives?
    Al.
    Nov 2012
    18
    I'll try and find out the model numbers for the drives, and I have used Mach before, so I understand the concepts there, what I am having difficulty with however, is how do I program the servo drives, given that they used to be programmed through the Allen Bradley controller, which is no longer functioning? Can I program the drives using a third party controller? for example a CSMIO/IP-A or Kanalog?
    Feb 2009
    6028
    Re: How to setup/program older analog drives without the original controller?
    What settings? Those were just an anolog input system. Usually just had pots to adjust gain/balance/etc. on the drives.
    Sent from my G-Tab Quantum using Tapatalk
    24220
    Allen-Bradley motors and drives were usually Reliance/Electrocraft as they had bought them out, if you can get the drive & motor model it will help?
    Al.
  1. Replies: 22
    Last Post: 04-18-2022, 11:54 PM
  2. Brother TC229 retrofit, can I keep the original servo drives
    By sbaer in forum Servo Motors / Drives
    Last Post: 02-18-2017, 08:33 PM
  3. Controlling Analog Servo Drives?!
    By MetalStorm in forum Servo Motors / Drives
    Last Post: 05-16-2014, 07:23 PM
  4. Dynomotion's Mill Retrofit for Analog Drives
    By TomKerekes in forum News Announcements
    Last Post: 04-29-2010, 07:07 PM
  5. Help With original Setup. Parallel port?
    By tehMadmachinist in forum DNC Problems and Solutions
    Last Post: 03-15-2007, 01:18 AM
