586,717 active members*
3,242 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Laser engraving machine not firing laser from software or controller.
    Jan 2011
    Hi everyone and thanks for taking the time to help me out.
    I purchased a Chinese Laser engraving/ cutting machine.
    I have done everything possible to get it to engrave a circle or even a simple square to no avail.
    I have attached a short video to show you what my problem is.
    http://youtu.be/16UOu3c1M6Y
    I hope it is an easy fix, but it never is.
    Jan 2011
    Re: Laser engraving machine not firing laser from software or controller.
    Ok, I figured out what the problem was. The chiller that came with the engraver is a cw 5200.Well, the chiller and the controller have a connection that in the even the chiller has an error it keep the laser from firing.
    I don't have that cable, so, no cable to play. What I did for the time being, is to jump the two pins with a screw. The screw goes between pin 1 and 3. Make sure not to touch pin 2.
    That tells the controller that the chiller is running without errors. I did that just to run the machine for a short while for testing only. My cable was sent from China within 24 hours of me contacting the agent there.
    We are humans and we all make mistakes, their mistake was not to send the cable. No harm done, things are being taken care off.
    I hope this might help someone else that might be going through the same. On another note, if you do have the cable and the machine does not fire, then the above might be a good way to troubleshoot the problem. Sometimes the chiller might be triggering the problems. Good luck and God Bless.
  1. HELP!!! Chinese Laser Engraver Not Firing While Running NewlyDraw Software!!!
    By Mitsuboy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-12-2014, 10:32 PM
  2. Do anyone know or bought this laser? LY3020 110v / 220v 50w LASER ENGRAVING MACHINE
    By 18111 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-17-2013, 06:50 AM
  3. Laser Cutting Engraving Machine Laser Cutter 1400*900mm
    By cnc_laser in forum Commercial Laser
    Last Post: 07-10-2013, 08:52 AM
  4. Laser engraving and cutting machine - software help!
    By hamleet in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-13-2008, 06:39 AM
