587,517 active members*
3,290 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Trouble with MAZAK QUICK TURN NEXUS 450-II MY using tailstock in front of steady rest
    Jan 2012
    13
    We have a Mazak MAZAK QUICK TURN NEXUS 450-II MY and we cannot get the tailstock to go in front of the steady rest. When we try we get a "soft limit" and we cannot move the tailstock any further.
    Is it even possible to do this? It looks like there is clearance.
    Any help would be appreciated.
    Dec 2012
    5
    Re: Trouble with MAZAK QUICK TURN NEXUS 450-II MY using tailstock in front of steady
    I have run in to this problem before unfortunately there is no easy solution
    The steady rest runs on the same rails as the tailstock, if you have the soft limit alarm the tailstock base is close to the steady rest
    If I remember correctly the soft limit alarm works off BA parameters but be careful, they are set close at the factory
    Some possible solutions
    Move the steady rest closer to the chuck
    Can you swap the steady to the other side of its base to get better clearance
    In the past I have made an extended centre
    Good Luck
    i don't believe this is possible. if you are not using the steady rest, take it off, and then the tailstock will reach over the base to allow you to support the part. these steady rests on the QTN450 are programmable, and all controlled by sensors.
  1. Mazak Quick Turn Nexus 200 lathe with Mazatrol 640 T-Nexus control
    By arwinder in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-15-2015, 04:50 PM
  2. Replies: 1
    Last Post: 04-14-2014, 07:49 PM
  3. problem with the Steady rest and tailstock
    By mateu5 in forum Hyundai Kia
    Last Post: 08-06-2012, 09:29 PM
  4. Mazak quick turn nexus 250ms 640t control
    By sidecar82 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-24-2012, 08:30 PM
  5. Problems with Mazak Quick Turn Nexus 350M
    By rolfsnes in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-20-2011, 11:34 AM
