Hi Phy6,
Not sure exactly what you mean by "setup" but we have example programs to configure 3 axes for Step/Dir. Such as for our KSTEP see:
C:\KMotion431\C Programs\KStep\InitKStep3Axis.c
I don't know of a specific Point Cloud measurement example. Here is an example (ProbeDirection.c in the C Code Examples) for a single probe operation that can be called from an M Code in GCode. I would suppose you would need some type of double loop to probe an array of points. Then write the points to a Disk File in some format.
Code:
#include "KMotionDef.h"
// For basic KMotionCNC Probing configure KMotionCNC to call this C Program
// with an MCode and 3 parameters P Q R passed in variables 50,51,52 to
// specify the X Y Z Probe directions speeds
// Modify this program for the input bit you are using for your probe. As
// written the program keeps moving until the bit goes high. If the polarity
// of your probe is opposit this then remove the NOT Symbol '!' applied to the
// ReadBit result.
// For Example:
// M100 = Exec/Wat/Sync Thread 2 Var 50 <>\C programs\ProbeDirection.c
// Then to probe in the X direction at 100 counts/sec use GCode as:
// M100 P100 Q0 R0
// Then to probe in the Y direction at 50 counts/sec use GCode as:
// M100 P0 Q50 R0
main()
Jog(0,*(float *)&persist.UserData[50]); // move in the velocites specified
Jog(1,*(float *)&persist.UserData[51]);
Jog(2,*(float *)&persist.UserData[52]);
// printf("X Y Z Speeds = %f %f %f\n",
// *(float *)&persist.UserData[50],
// *(float *)&persist.UserData[51],
// *(float *)&persist.UserData[52]);
while (!ReadBit(46)) ; // wait for switch to go high
Jog(0,0); //Stop
Jog(1,0);
Jog(2,0);
Regards
