587,531 active members*
3,238 visitors online*
Thread: Haas VF2
    Dec 2005
    25
    Haas VF2
    I'm looking at a 2006 VF2. it has a 12" monitor.
    Can anyone tell me what the difference is between
    it and the 15" color. Other than the color is there any difference?
    in using it? Seems to me the color has more information on the screen.
    Any information is appreciated. I have no experience with Haas.
    Thank you!
    Mar 2010
    1852
    Quote Originally Posted by TRANSATOOL View Post
    Thank you!
    Unless the monitor has been swapped out or something, I don't think it's a matter of the monitor itself, but what software version is installed on the machine. Older machines had different software and you can't upgrade by just changing to a color monitor.
    Mike
    Jul 2005
    12177
    There is a lot more information on the screen of the 15 monitor. These monitors and the associated machine software versions started being introduced around 2008 or 2009, I have several machines from just before and after those dates and the early ones dating back to 2006-7 have the 12 while some I bought in 2008-9 have the 15. Personally I am used to the 12 and the 15 confuses me because things are in different places and paging through the screens uses different key sequences.
    Dec 2008
    717
    Thank you!
    I've got the 2006. Monitor is great. Don't buy it or not buy it because of that.
    Tim
  1. Replies: 4
    Last Post: 06-28-2013, 02:00 PM
  2. Replies: 2
    Last Post: 04-03-2012, 04:31 PM
  3. haas SL-20 to Haas bar 300 alignment plate needed
    By J-Mccoin 2009 in forum Haas Lathes
    Last Post: 12-03-2009, 04:13 AM
  4. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
