587,004 active members*
2,768 visitors online*
Hybrid View
    Nov 2008
    6
    EZ Trak runtime error m601
    Hi, i recently had to replace the cmos battery on my EZ Trak SX. All was working fine for the last few weeks since doing so. Yesterday how ever the machine started up fine, but while running a program an error message came up on the screen:
    Run time error m601:map
    floating point error: invalid
    Loading ez utils
    I also notice when the machine loads the program after starting up, it has moved the starting position of the program by around 1/8".
    Could anyone give me an idea of what this problem is, and what i can do to remedy it?
    Mike
    Mar 2008
    11
    Re: EZ Trak runtime error m601
    did you Find a solution to this Problem? Our EZ trak is currently doing the same thing and I am having my Employee restart the mill to see if it will get him back working.
    Jason
    Nov 2008
    6
    Hi Jason
    The answer to my problem was that the backup battery on the computer needed replacing. I found in some cases the backup battery pops out of the motherboard and you just replace it with another battery. But in our case the battery was soldered into the motherboard and you have to remove the motherboard from the back of the machine to remove the battery by unsoldering it then resolder the new battery in place and refit the motherboard. Hope this helps.
    Regards
    Mike
  1. Coreldraw X4 and Lasercut 5.3 runtime error 429
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-02-2014, 09:05 AM
  2. v-25 demo runtime error
    By 1234567 in forum BobCad-Cam
    Last Post: 05-29-2012, 11:39 PM
  3. Runtime error
    By ARHEA in forum EnRoute
    Last Post: 05-17-2012, 06:43 PM
  4. Runtime error
    By msme-lc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-30-2008, 10:14 PM
