587,434 active members*
3,150 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > where to find aluminum t slot material?
Results 1 to 12 of 12
    Jan 2014
    44
    Hi all, I have a 3020 chinese cnc. My aluminum t-slot has gotten a bit damaged over time and I'm curious where I can find the same aluminum t slot I have on it now. Any suggestions would be greatly appreciated. Thanks again! You all are great!
    Nov 2007
    25
    Nov 2013
    26
    Try Mc master carr
    or MSC for mail order
    Nov 2010
    520
    Try Misumi or Automation4Less. Both are real easy to deal with.
    And then there is always 8020inc on ebay. I've bought many things from them. Good prices, but brace yourself for the shipping cost.
    Fractional Metric Profiles Fasteners T-Nuts Brackets items in 8020 Aluminum T-slot Extrusions store on eBay!
    Nov 2012
    18
    If you contact bosch rexroth, or 8020 t-slot from their website they will direct you to a local supplier.
    Re: where to find aluminum t slot material?
    I use Faztek extrusion, via Amazon. It ships free with Amazon Prime.
    Amazon.com: faztek
    Best,
    JBR
    Jan 2015
    Hi guys,
    I am preparing my first CNC on the drawing board, love to read this forum while doing so. I am very interested and thankful about the links you guys posted here. I was wondering if you knew were to find metric aluminium extrusion files for Sketchup. Parker IPS have a few files, very helpful, but they are missing pieces and everything is in imperial units, which is kind of an problem for me.
    Thank you for your help
    Cheers
    Feb 2016
    Hiroshiman,
    Try www.8020.net - they have downloads of all there aluminum extrusions material. I believe you can create the size in metric then download.
    Dave
    Nov 2007
    25
    Or here. Buy direct from them. Pretty much any size you want.
    Framing Tech
    Mar 2014
    735
    It looks like 8020.net updated their website. Last time I tried to order directly from them they referred me to the nearest engineering affiliate to order through. I just put together an order and progressed through the the shipping phase of checkout and it was pretty user friendly.
    Aug 2015
    11
    You can purchase directly from 80/20 Inc. now, but you will be paying full list price. If you buy from a top tier distributor, you can usually negotiate a discount. We support CNC builders nationwide, and your order ships directly from the factory to your location. Visit the F&L Industrial Solutions store at F&L Industrial Solutions, Inc. | T-Slotted Aluminum Extrusion Experts to save 10% on all your 80/20 needs - just use this discount code at checkout:
    cnc10off
    In our opinion, 80/20 offers the highest quality t-slot extrusions available with superior anodizing/color - and very tight tolerances, so you won't be disappointed when you measure your new machine for mechanical slop after its all built.
    Jun 2012
    182
    It's unlikely the OP's Chinese machine used 8020 extrusions. :stickpoke
  1. Find a vendor for t-slot table top
    By Ajax451 in forum Complaints and Praise Discussions
    Last Post: 02-13-2009, 11:56 AM
  2. T Slot Material
    By gunlocators in forum DIY CNC Router Table Machines
    Last Post: 08-29-2008, 06:47 AM
  3. Metric or Fractional T-Slot material?
    By jeffmorris in forum Joes CNC Model 2006
    Last Post: 08-25-2008, 08:43 PM
  4. Slot Cutter Holder Arbor type, cant find??
    By mgb1974 in forum MetalWork Discussion
    Last Post: 03-10-2008, 01:36 PM
  5. help - where to find 8020 t-slot alum
    By landart in forum DIY CNC Router Table Machines
    Last Post: 08-01-2003, 02:45 PM
