586,766 active members*
8,466 visitors online*
Thread: Boring Help
Results 1 to 9 of 9
    Feb 2014
    11
    Boring Help
    Hello! My FRC team is attempting to boar 4 1.132" diameter holes in .13" thick 6061 aluminum on or PCNC 1100 to press fit bearings into. We could use some help figuring out feeds and speeds and if there is any way to automate a boring process using SprutCAM 7. Any help would be greatly appreciated, thank you.
    Oct 2011
    477
    With the tools I have on hand for my 1100, I would circular interpolate to rough size the hole, then tool change and finish with a boring bar in a boring head.
    Can't help with Sprut
    nitewatchman
    Nov 2013
    402
    I would circle interpolate the 4 holes with a good, new endmill instead of boring them.
    If you're only going .130 deep, your TORMACH should have no problem holding .0005 tolerance for a bearing fit.
    Jun 2006
    340
    Sprut will do what you want. Post in the Sprut forum.
    Bevin
    PS. Disregard this if I was successful the first time I tried to send it.
    Feb 2009
    328
    We used to simply mill and ream. Works great and simple.
    Oct 2008
    44
    Hi JD, We circle mill the bores with .005 excess then bore at 500 RPM and 1.0 IPM. Good luck in the competition.
    Kevin
    Feb 2008
    389
    Will these video's from Tormach help out?
    Gerry
    PS
    I could help you with SC7 if you choose to do one of the methods mentioned by the fellas above, don't see any thing in tools in SC7 for a boring op, but I just took a quick look.
    Currently using SC7 Build 1.6 Rev. 64105
    Feb 2008
    389
    Here is part 2
    Dec 2012
    59
    For FRC purposes I've always used a normal circle interp roughing/finishing process. With good tooling you shouldn't have much trouble getting a reasonable fit. Retaining the bearing in a slightly loose hole can be accomplished with high strength loctite or, my personal favorite, a bit of peening. A looser fit also greatly reduces the difficulty of getting the bearing pressed in correctly in thin material.
    Good luck in the game!
  1. Replies: 0
    Last Post: 07-24-2013, 07:03 AM
  2. Boring a Pocket in Lathe with Boring Bar Help
    By blakemachine in forum Mastercam
    Last Post: 04-25-2012, 01:15 PM
  3. Indexable boring bar in boring head?
    By Molochnik in forum MetalWork Discussion
    Last Post: 04-15-2010, 01:36 PM
