Hi Seth, Ok I went back over the thread and saw that you have the Glentek SMA-8215 AC drives.
From the 8215 manual " Over/under voltage These circuits constantly monitor the amplifier power-supply
and over temperature: voltages, and the motor and amplifier-heatsink temperatures.
They will shut down the amplifier in the event of any out-ofspecification
condition. (The overvoltage protection circuit is set
to turn on at +250VDC for 120VAC line input and +450VDC for
240VAC line input.)"
Unless your machine was built for over seas export it should be wired for 120V input.
can I get the machine serial # and i will check on this.
