586,936 active members*
2,279 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > osp5020m 596B alarm
Results 1 to 10 of 10
    Jan 2014
    12
    osp5020m 596B alarm
    Some former coworkers, with a company that folded, aquired one of the Okuma 4-VMCAE mills, that we used, from the auction. When they got it set, and fired it up, a 596b alarm came up. They did not get the alarm code manual (there is one on order).
    The alarm says "spindle head cooling" All of the cooling systems are working. Is it just a sensor?
    How can I get this alarm cleared?
    Mar 2009
    1982
    have you electric circuit diagram of this control?
    Jan 2014
    12
    We have found that it is the spindle head heat sensor relay. They are looking for the diagrams. Any ideas without a diagram?
    Sent from my SCH-I545 using Tapatalk
    Mar 2009
    1982
    no need of diagrams. You did diagnostics already. Check connections, and replace the relay in case if connections are good.
    Jan 2014
    12
    We are trying to find the correct relay...it is hard because I a not there until tomorrow. They don't know anything about the machine and I know very little about that end of it.
    Jan 2014
    12
    Success....blown fuse. Proud to say that we are up and running.
    Jan 2015
    What fuse was it?
    Jan 2015
    3304722150. If u could call or text me that wud be great. Im having all kinds of troubles
    Jan 2015
    Machine is up and running. Replaced overload relay number 5
    Quote Originally Posted by rswdew View Post
    Hello. I have the same machine and the same alarm . 596 spindlehead cooling unit . You said you replaced a fuse? Any more info on what fuse and location. Thanks! It would help me out big .
  1. OKUMA OSP5020M HELP
    By KENNY D in forum Okuma
    Last Post: 05-18-2014, 04:12 AM
  2. MC-500H osp5020M - 139 alarm A
    By cnc312 in forum Okuma
    Last Post: 09-11-2013, 08:53 PM
  3. MC-500H osp5020M APC shifter.
    Last Post: 02-13-2013, 03:52 PM
  4. need osp5020m manuals
    By guydrisc in forum Okuma
    Last Post: 11-01-2010, 05:48 AM
  5. MC-4VAE/OSP5020M - Alarm B 539
    By LancoUSA in forum Okuma
    Last Post: 02-05-2008, 01:42 PM
