586,655 active members*
3,856 visitors online*
Thread: Maho 432
Results 1 to 8 of 8
    Jun 2013
    8
    Maho 432
    Hi all, i have problem with my Solidcam pp.
    -my helical milling is going thrue point, not spiral and helical interpolation,
    as you may see, my aproach is good but rest of milling wont go thrue I J K and i desperatly need that.
    I tryed to edit PRP and GPP files but no success.
    Thank you for your Help
    Mirko
    Attached Files Attached Files
    Feb 2013
    49
    do you mind sharing your cam part so i can take a look? you can't expect IJK if it is moving in linear (G1) so i don't see any problem with your NC file. i will need to see your cam part to see what can be done.
    Jun 2013
    8
    I sent you PM mate.
    Feb 2013
    49
    i see the issue... you don't want to have line moves and prefer to get arc moves due to controller issue.... nothing is wrong with your post processor or prp file. If your intention is just to cut that hole with arc moves, don't use HSM operation. HSM operation uses target (surface or solid) so therefore it creates lines. You can either use profile operation instead. Let me check if I can force HSM to create arc moves instead of lines, although I tried changing tolerance but did not help.
    Jun 2013
    8
    Yes but when i use profile cuts, i might not be able to use it with conical shapes and a bit more complex shapes with complex angles.
    Am i right?
    Feb 2013
    49
    you still can use profile for simple conical shapes or any shape as long as the top and bottom profile is the same, shapes that are tapered with top and bottom having the similar profile.
    Feb 2013
    49
    in the misc parameter, uncheck the option approximate arcs by lines and see if it will give you more arc moves than linear.
    Jun 2013
    8
    knew that, i prove my point to friend, and thats all, and thank you for help. my pp works just fine
    king regards mate
  1. maho mc 5 hs
    By ihavenofish in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 04-16-2014, 04:40 AM
  2. MAHO 500
    By Arjuna in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 06-27-2013, 05:02 PM
  3. Maho 500C and Maho 500 E2
    By F45CNC in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 06-10-2013, 10:39 PM
  4. Maho MH 600 P
    By CNC Metal in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-18-2010, 01:30 PM
  5. Maho MH 600 P
    Last Post: 01-31-2008, 02:41 AM
