586,847 active members*
2,415 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Really Basic Drill Press vs Mill Question!
Results 1 to 10 of 10
    Apr 2006
    1257
    Ok, you folks using mills for years will probably bang your heads against the wall at this but here goes.....
    1) (Ignoring the ability to adapt a mill for cnc) Whats the difference between a benchtop mill and a benchtop drill press?
    2) Can a drill press do everything a mill will do if fitted with the correct bit?
    Mar 2005
    1136
    in short bearings. in long, on and on. basically the dp bearings aren't as robust or designed to take the side load that a mill's are, the dp takes an axial load while the mills takes this plus a heavy radial load. There are other problems such as no drawbar so what ever you're holding the tooling with will tend to pop out. if you do some searches here and in the some of the metal working forums, there's lots on this topic
    Apr 2006
    1257
    Ok. Thanks McGyver.
    Dec 2005
    3319
    You can mill and drill properly and righteously with a mill.
    A drill press is for DRILLING.
    Once you get a mill, you'll find the you hardly use the drill press any more. You will probably find that it (the press) is simply too crude by comparison.
    Apr 2006
    1257
    Thats interesting because I was going to buy the drill press and get a mill later.
    But maybe I should just get a big mill for doing everything?
    I will be doing a lot of work with wood initially so thats why I thought a floor standing drill press would be useful by itself...maybe this is not so?
    I know Im going to have to get a mill later on for more precise metalwork....but thought the drill press with a suitable bit would do me for a while....
    Dec 2005
    3319
    You can do pretty much ANYTHING you want/need to do with the drill press with the mill BUT you can NOT mill worth a darn with a drill press.
    Buy the mill, you won't be disappointed.
    Apr 2006
    1257
    Can I put a morticing attachment onto a mill?
    Jul 2005
    12177
    Quote Originally Posted by diarmaid
    Are you talking about these devices which have an auger bit running inside a hollow square chisel? The square chisel cuts out the corners and deflects the chips into the auger which takes out the center and all the chips.
    For this the answer is yes; actually a benchtop mill is the best choice for this because it is more rigid and you can have better control of the downfeed on the quille by using the supplementary feed wheel rather than the hand lever.
    About the only thing you can do with a bench drill that is not easily done with a benchtop mill is mount a drill close to the corner of your bench so you can rotate the head to the side and drill the end of long pieces by standing them on the floor.
    Apr 2006
    1257
    Ok. Sounds good. Mill it will be....if I can get one that is big enough but not too expensive and will take a morticing attachment.
    (Yes the hollow square chisel with the drill bit is for cutting mortices. But they require a special adaptor to mount them onto a drill press and I assume also a mill. They are usually used with a morticing machine which looks kinda like a benchtop drill press)
    Dec 2005
    3319
    Spend a little bit more than you think you can afford and buy the better machine.
    Ultimately, you WON'T be disappointed...
