587,920 active members*
3,475 visitors online*
Results 1 to 7 of 7
    Mar 2005
    816
    Mitsubishi CNC boards / cards
    I just received several pallates of old Mitsubishi CNC boards stripped from old CNCs.
    Most of the boards are labeled with a MCxxx part number. Many of them are MC3xx numbers but a few are MC4xx and MC6xx and MC7xx
    Also a few of
    LXxxx
    FXxxx
    QXxxx
    QYxxx
    PDxx
    GXxx
    A few contol units UF01A, B and C.
    Also UF701A and B.
    Anyone tell me which model(s) they are from?
    There appears to be enough to build at least two complete systems. Next week I will receive more.
    I think these are from the 300 series.
    I can give board numbers
    As far as I know ill end up with several hundred boards.
    24220
    Looks like some from Mazak (Mitsubishi) CAM T2-T2 L2-L3 ?
    Al.
    Mar 2005
    816
    Well, I took a chance downloaded the connection manuals to see lists of board numbers.
    They're mostly from the 300 series Meldas.
    Only a few from the 500 series.
    MC301B
    MC301D
    MC303B
    MC303D
    MC323
    MC011D
    MC011C
    MC111B
    MC411B (Several versions of this)
    MC437D
    MC413 (several versions of this)
    MC714
    MC723
    MC727
    MC721
    MC442
    MC446
    MC456
    MC095
    MC611
    MC433
    MC724
    MC461
    MC201D
    MC616
    Missing any?
    Oct 2003
    321
    Meldas 335 ( used in Mazatrol T32 or M32 )
    best regards
    mazak-user
    Mar 2005
    816
    I was wondering if they may be mostly for the Meldas M3/M3x/3xx series.
    The FX and QX boards look way different and look as though they are the 50/500 series or for the 0.
    Im awaiting what more is coming which I also am hearing is several pallates of more boards and keyboards, drives, a few servos, crt/mdi. Seven of the units also say UFxxx and FCA or FCUA.
    The seller is only keeping the Mitsubishi PLC and standard automating equipment, VFDs etc.and not keeping the Mitsubishi CNC stuff they buy in large lots.
    Never used the Freqrol or the MDS-S drives with the SF or SFj types. What servos do I need to look for?
    Aparently there is a complete dynapath too in the one lot coming.
    I asked to have them keep shipping me all the Mitsubishi CNC stuff they get from now on.
    Oct 2003
    321
    Have you any FR-SFJ-2-7.5k
    Gesendet von meinem PAP5000DUO mit Tapatalk
    Mar 2005
    816
    I will look and see if I do. I'm working on hooking up mine to the control.
  1. Open Source Boards Available, Stepper Drivers and Break Out Boards
    By pminmo in forum Open Source Controller Boards
    Last Post: 06-23-2018, 01:46 AM
  2. Bad Cards.
    By neilthib in forum Fadal
    Last Post: 08-28-2013, 02:49 AM
  3. acramatic 900 BOARDS AND CARDS
    By PICMAN in forum Controller Cards
    Last Post: 11-24-2009, 03:12 PM
  4. Ever used these Stepper cards?
    By bearwen in forum Controller Cards
    Last Post: 08-16-2007, 01:19 AM
