586,655 active members*
3,596 visitors online*
    Jan 2009
    10
    VMC 1000 X AXIS HOMING PROBLEM
    I recently purchased a 98 Model VMC1000 which I saw under power prior to the machine being moved to my shop. Upon powering it up after the move the X axis is showing limit on the screen but the limit switch itself is probably close to an inch from its stop. Anyone have any idea what this might be? Any help would be much appreciated. Thanks in advance.
    Oct 2008
    44
    does it work on a linear scale? When other axes homing, they home by moving to the axes end or moves just a little to complete the homing progress?
    Nov 2004
    3028
    What control?
  1. Arrow 1000 Y axis problem / Vickers AS10300 codes
    By Chaz in forum Cincinnati CNC
    Last Post: 02-24-2020, 08:31 PM
  2. Homing Problem
    By red_alert in forum LinuxCNC (formerly EMC2)
    Last Post: 08-15-2010, 03:50 AM
  3. Z axis homing problem
    By BillTodd in forum LinuxCNC (formerly EMC2)
    Last Post: 08-26-2008, 08:55 PM
  4. Problem With Homing X Axis
    By elalto in forum Mach Software (ArtSoft software)
    Last Post: 09-16-2006, 01:28 AM
  5. Homing Problem V4.0.1
    By BMaynard in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-13-2006, 07:22 AM
