586,845 active members*
2,415 visitors online*
Results 1 to 8 of 8
    Nov 2013
    4
    Kflop e programming
    Can I make my own with an application software kFlop in Delphi 7?
    I ask for help to Tom Kerekes
    May 2006
    4047
    Hi RimappaGCode,
    Sorry I'm not familiar with Delphi. But I would assume it would be possible if you can figure out how to call DLLs from Delphi. I think the KMotion_dotNET_Interop dlls would work. I know it works with Borland Builder.
    HTH
    Regards
    TK
    http://dynomotion.com
    Nov 2013
    4
    1) con quale compilatore devo compilare il programma KMotionWebNC oppure KMotionCNC?;
    2) Posso modificare i codici sorgenti di KMotionWebNC e KMotionCNC per fare un nuovo programma?
    3) Dove si trova la documentazione per fare ciò?
    Grazie
    1) with which compiler I have to compile the program KMotionWebNC or KMotionCNC?;
    2) Can I modify the source code of KMotionWebNC and KMotionCNC to make a new program?
    3) Where is the documentation to do this?
    thanks
    May 2006
    4047
    #1 - Visual Studio 2008 Standard (it is possible with the Free Express Version but more difficult)
    #2 - Yes
    #3 - We only have the examples
    # 1 - Visual Studio 2008 Standard (è possibile con la versione gratuita Express, ma più difficile)
    # 2 - Sì
    # 3 - Abbiamo solo gli esempi
    Regards
    (saluti)
    TK
    Nov 2013
    4
    I open KMotionCNC using Visual C + + Express, but I do not see the forms of "KMotionCNC" and "G Code Viewer". Why?
    Riesco ad aprire KMotionCNC tramite Visual C++ Express, ma non vedo le forms di "KMotionCNC" e "G Code Viewer". Perchè?
    May 2006
    4047
    Hi RimappaGCode,
    The free express versions doesn't support MFC applications. See this post on our Group.
    Yahoo Groups
    Regards
    Nov 2013
    4
    Si può fare il debugging di KMotionCNC utilizzando Visual C + +? ---->> You can do KMotionCNC debugging using Visual C + +?
    Attachment 211996
    May 2006
    4047
    Hi RimappaGCode,
    Yes. You will need to build the debug configuration of KMotionCNC. You will also need to build the debug version of our Libraries. Load the BuildAlllibs.sln solution and build the debug configuration.
    It would be simplest if you use the version of Visual Studio we use: Visual Studio 2008 Standard. But other versions are also possible.
    Regards
    Ciao RimappaGCode,
    Sì. Avrete bisogno di creare la configurazione di debug di KMotionCNC. Avrete anche bisogno di costruire la versione di debug delle nostre biblioteche. Caricare la soluzione BuildAlllibs.sln e costruire la configurazione di debug.
    Sarebbe più semplice se si utilizza la versione di Visual Studio che usiamo: Visual Studio 2008 Standard. Ma altre versioni sono inoltre possibili.
    Saluti
    TK
  1. kflop with snapamps
    By George Butty in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-16-2016, 08:46 PM
  2. KFlop 4.3
    By John Coloccia in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-03-2013, 07:57 PM
  3. Kflop and pokeys together
    By gavztheouch in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-18-2012, 01:16 AM
  4. Mach3 vs Kflop
    By MarunovV in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-25-2012, 08:54 PM
  5. KFLOP Capabilities
    By Rob K in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-26-2011, 05:57 PM
