586,936 active members*
2,115 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Acramatic 2100 Alarm 44-84
Results 1 to 20 of 21
Hybrid View
    Nov 2013
    4
    Hello!
    After 2 batteries replacement (my big mistake), when Vikkers load, in diagnostic procedure I see CONV. SERVO failed.
    And then alarm window 44-84 (no axes configured) DV5 board. I check this board in other Cincinnati, and in diagnostic is Passed!
    So, apparently I need to re-flash RT board? Or not?
    I have all hardware for RT board (3-3424-2169A03) for connecting and computer skills, but have no idea, where to get CMOS file.
    Please help with this procedure, before my boss fired me.
    Thanks!
    Oct 2011
    205
    Get in touch with 5's Fives Machining Systems Inc.: Fives and the can tell you the settings that need to be made. It is my experience that the you do not necessarily need to reflashed, but rater just have the settings set back to proper specs for the board. I have info here for Board 3-424-217xA0x and Board 3-424-234xA0x , but don't know if they will do you any good, but here they are...
    Board 3-424-217xA0x
    Board 3-424-234xA0x
    AMI Version 1.00.06.BRO
    Main Menu....
    Date Today
    Time Now
    Floppy Options Press Enter
    Primary IDE Master Not installed
    Primary IDE Slave Not installed
    Secondary IDE Master Not installed
    Secondary IDE Slave Not installed
    Language English (US)
    Boot Options Press Enter
    Video Mode EGA / VGA
    Mouse Not Installed
    Base Memory 640 KB
    Extended Memory 15360 KB
    Floppy Options...
    Floppy A: Not Installed
    Floppy B: Not Installed
    Floppy A Type: Disabled
    Floppy B Type: Disabled
    Primary and Secondary IDE Master - Slave Configuration....
    IDE Device Configuration Disabled
    IDE Translation Mode Auto Detected
    Multiple Sector Setting Auto Detected
    Fast Programmed I/O Modes Auto Detected
    Boot Options....
    First Boot Device Hard Disk
    Second Boot Device Floppy
    Third Boot Device Disabled
    Fourth Boot Device Disabled
    System Cache Enabled
    Boot Speed Turbo
    Num Lock Off
    Setup Prompt Enabled
    Hard Disk Pre-Delay Disabled
    Typematic Rate Programming Default
    Scan User Flash Area Disabled
    Advanced Menu....
    Processor Type Pentium ™ Family
    Processor Speed 75 MHz
    Cache Size 256K
    Peripheral Configuration Press Enter
    Advanced Chipset Configuration Press Enter
    Power Management Configuration Press Enter
    Plug and Play Configuration Press Enter
    Peripheral Configuration....
    Configuration Mode Manual
    Primary PCI IDE Interface Disabled
    Secondary PCI IDE Interface Disabled
    Floppy Interface Disabled
    Serial Port 1 Address COM 3 3E8 IRQ4
    Serial Port 2 Address COM 4 2E8 IRQ3
    Serial Port 2 IR Address Disabled
    Parallel Port Address Disabled
    Parallel Port Mode Compatible
    Base Memory Size 640 KB
    ISA LFB Size Disabled
    Video Palette Snoop Disabled
    Latency Timer (PCI Clocks) 66
    Configuration PCI Burst Enabled
    Bank 0 SIMM Detected EDO Mode
    Bank 1 SIMM Detected Fast Page Mode
    Power Management Configuration...
    Advanced Power Management Disabled
    Plug & Play Configuration....
    Configuration Mode Use Setup Utility
    ISA Shared Memory Size 64K
    ISA Shared Memory Base Address D0000h
    IRQ 5 Used By ISA Card
    IRQ 7 Used By ISA Card
    IRQ 9 Used By ISA Card
    IRQ 10 Used By ISA Card
    IRQ 11 Available
    IRQ 12 Used By ISA Card
    IRQ 14 Used By ISA Card
    IRQ 15 Used By ISA Card
    Security Menu....
    User Password is Disabled
    Administrative Password is Disabled
    Set User Password Press Enter
    Set Administrator Password Press Enter
    Note - No passwords used on normal setup
    can you tell more if all the boards are passing the tests. can you go into settings and check if your servos are configured or did you loose your data. while booting up are there any problems. you have to see that as two simple motherboards booting up. the problem with the rt board is that it has to boot up all by itself without u seeing it. so make sure all bios parameters are ok and the board boots up even after some time without any problems. it has to go till it tells u no operationg system found...and that without showing any error before that. most important parameter are pnp(plug and play parameter) as enabled. and a drive as not installed or disabled... while in operation there shold be no red lights on on the bridge board. that will be confirmed that both i o card and servo card will pass the test. make a lot of screen shots that way well be able to define the error. one more thing you can try is to chkdsk your harddisk chkdsk c: and chkdsk d: and chkdsk /f c: and chkdsk /f d:. this way you know if you have errors on your disk and with the /f command you can fix it. don t do that without someone who has somehow some experience.
    Nov 2013
    4
    now this problem is solved, by changing some files in program. all of boards was Ok. we are lost our HDD, and problem began from there. now it work.
    other serious problem that we have a lot of time, is the spindle rpm falling down after few minutes of work, and after 3-4 seconds his rpm coming back.
    this occurs each time a few minutes of operation. it happens also when we turn on spindle in MDI: (M3S1200 for example). I think it`s spindle driver,
    because we check his on the other cincinnati machine and get same result.
    may be somebody know this problem and find decision?
    thanks a lot to all of you.
    Jul 2014
    10
    viel can you tell me which file you replace pleas!
    because i have the same problem
    Jul 2014
    10
    need help
    Jul 2014
    10
    Unhappy Re: Acramatic 2100 Alarm 44-84
    pleas i need to know which file changed because i have the same problem
    can anyone help me ?
    thanks
    Nov 2013
    4
    Quote Originally Posted by SolSql View Post
    thanks
    sorry, I don't remember. to match time go away. we send the computer to repair guy, and he is do the work. if I not mistake, he is take a backup from other same machine, and change our HDD by Compact Flash card. computer begin to load very quickly. and all detail of repairing he is don't tell to us, because it he's money. he is help to get for us used spindle driver from USA, and problem with rpm falling down -was solved. sorry,if it can't help you. I don't work there anymore.
    Jul 2014
    10
    Quote Originally Posted by viel View Post
    thanks viel
    Hi Sol,
    did you solved the problem? I have the same alarm
    Apr 2015
    77
    Does anyone on here have a running A2100 with a 3-424-2123A ws-board?
    I need the BIOS settings after resurrecting a dead DALLAS chip. A write-up like @coop31 did would be extraordinary nice!
    Hi Sol. I sent you my phone number. You can call me any time and I can come and check it out.
    Apr 2009
    35
    Did you lose the Bios settings for RT-board, Sol? And are you capable of flashing it yourself?
    If so you need to identify the rt-board id-number.
    Jul 2014
    10
    thanks mvas82
    yes i removed the bios battery to Chang it and i also take a backup from the HD
    now i already set the bios again and i have a mini prog and good exp. in microcontroler and EPROM but i think the bios is good because i started up the mother board by external power supply and VGA
    Jul 2014
    10
    thanks kabdelwahid
    pls can you send you number again
    Dec 2006
    585
    I think we are talking about 2 different things. What coop31 gave us is the BIOS settings that are in the Workstation board (far left board) and are retained by a 2032 watch battery. What you lost by changing the 2032 battery in the REAL TIME board (far right board) is the complete BIOS. This needs to be re-flashed to work correctly. The BIOS settings are different depending on the type of processor and board/part number. There are people on this site that can re-flash the BIOS or, you can send it to SIEMENS 1-800-879-8079. You need to look at the similar posts about this subject. Let us know what happens.
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Jul 2014
    10
    Quote Originally Posted by meckardt55 View Post
    hi everyone
    i get an AT power supply and AT keyboard and old VGA card and i run the RT board to set the bios
    of it ,the alarm for output fuse is gone but still tow alarms (servo.config) and (problem mapping pendant/panel)
    Dec 2006
    585
    What did you do to resolve this problem??? What was the end result??
  1. CICINNATTI MILACRON - ACRAMATIC 2100 ALARM-APC RACK 0
    By CHANDRU in forum Cincinnati CNC
    Last Post: 03-03-2015, 08:35 PM
  2. Acramatic 2100 alarm 17-28
    By PeeBee in forum Cincinnati CNC
    Last Post: 02-05-2015, 04:26 PM
  3. Acramatic 2100 mid tool change powerloss, cant remove alarm
    By taxslave in forum DNC Problems and Solutions
    Last Post: 02-26-2014, 10:23 PM
  4. Acramatic 2100 Alarm 39-21
    By STREEM in forum Cincinnati CNC
    Last Post: 12-21-2012, 10:44 AM
  5. Need help acramatic 2100
    By logger in forum CNC Machining Centers
    Last Post: 03-19-2011, 11:41 PM
