587,006 active members*
2,941 visitors online*
    Feb 2012
    9
    servo motor holding issue
    I'm using DC permanent magnet servo motor with carbon brush for the our Unison CNC tool grinder .
    im facing some problem on this motor . Motor is continuously rotating when i'm giving signal hold the motor . I'm confusing , problem with tacho ?motor ? or encoder ?
    please help me to fix this issue
    24223
    What controller are you using?
    Al.
    Apr 2012
    7
    It looks like you have a tach issue.if a scope could get you the answer for the encoder by checking your channels.
    Feb 2012
    9
    Yes Potomag, you said right , I have replaced the tacho , now it is working fine. thanks 4 the reply .
    Apr 2012
    7
    good for you...some times ripple on the tach could drive the machine on wrong direction.
  1. servo holding torque
    By marzetti in forum Servo Motors / Drives
    Last Post: 02-29-2012, 03:47 PM
  2. Servo holding torque
    By Instance in forum Servo Motors / Drives
    Last Post: 01-11-2012, 02:08 AM
  3. Servo motor? tool change issue
    By richpsr in forum Bridgeport / Hardinge Mills
    Last Post: 10-04-2011, 12:57 PM
  4. Servo Motor Issue??
    By Trebol in forum Fadal
    Last Post: 08-15-2011, 06:35 PM
  5. How do Servo's have holding torque ?
    By LUCKY13 in forum Servo Motors / Drives
    Last Post: 03-03-2009, 07:21 AM
