Hi! I have a CNC3020 Chinese router. Unfortunately the motor speed controller has been broken. The spindle motor is dead. Checking the controller card, see attached photo, I can see that one resistor has been badly smoked. It is R1. R1 is connected to the ground pin of U2, a 78L05 5 volt regulator. Checking the output voltage of U2 it is found to be zero. I will replace the U2 IC as well as R1.
My problem is that I can’t see the value of R1, it is too heavily toasted. Could anybody that has a CNC3020 help me to check the value of the resistor? It has to be replaced.
Thanks in advance!
Regards
Bo, SM6FIE
