587,691 active members*
3,535 visitors online*
Hybrid View
    Sep 2007
    84
    Simple g-code program assistance
    Hello,
    I am starting a project in which I will need a large number of small pieces; in the hundreds. I will cutting hollow brass rod. I'd like to create a program in which will run the cross of the lathe at a specific speed and travel then return and stop. I will be manually setting the stock to a depth stop. I have Mach 3 for control.
    Any assistance or being pointed to a thread or other resource would be appreciated.
    Thanks in advance.
    Craig.
    Sep 2007
    84
    I think a have and easy solution. I can type x-.75 the x0. Then use the arrow key to switch between the 2 locations.
  1. Simple program
    By KeithCoffee in forum CamSoft Products
    Last Post: 01-10-2012, 09:39 AM
  2. help with simple program
    By poster in forum Milltronics
    Last Post: 09-15-2011, 10:12 PM
  3. fanuc program code vs. Haas code
    By sixty8frbrd in forum Fanuc
    Last Post: 03-11-2011, 04:05 AM
  4. Just need a simple program
    By Steve Crum in forum Uncategorised CAM Discussion
    Last Post: 02-24-2010, 06:09 PM
  5. Simple G-Code program?
    By N4NV in forum G-Code Programing
    Last Post: 03-25-2006, 01:35 AM
