586,796 active members*
2,673 visitors online*
IndustryArena Forum > CAM Software > UG NX > Ramp toolpasth/Lead in-lead out (engage) question
    Feb 2008
    92
    Hello
    I'm new to NX but experienced with Mastercam. I have a part that is shaped like a picture frame and I'd like to cut out the center material. I don't want to waste time hogging out all the material, I just want to bolt the center material to a fixture and cut it out. In matercam I would use a ramp toolpath that just ramps down into the material at a given increment each pass. If that type of toolpath doesn't exist in NX, I could just do depth passes but I'd want to ramp into the material with a lead in. Can someone give me some direction? I've tried Solid_Profile, ZLevel_Profile, Planar_Profile, and Planer_Mill. I think I got closest with planer_profile.
    here is a video of what I'm trying to explain.
    ramp example - YouTube
    I also attached a pic of what I have in NX
    Thanks in advance
    146
    Ramping cut
    This can be done in NX with Planar Milling. Create the boundary at the top of the part and the floor at the bottom. Set the cut pattern to follow periphery and make the stepover extremly large so you only get 1 profile pass. Set the non-cutting engage type to Ramp on Shape and set a shallow ramp angle. You may need to modify the minimum clearance but this should get you started.
    See the attached file
    John Joyce -NC Programming Supervisor
    Barnes Aerospace, Windsor CT
    Apr 2012
    40
    You could also use a Fixed Contour op., use Surface Area drive method, select the inside wall surfaces, select Helical as the Cut Pattern, set Stepover to Scallop, and Vertical Limit to the preferred Depth per pass.
  1. Replies: 3
    Last Post: 06-25-2013, 04:54 AM
  2. 2D Contouring Lead-in / Lead-out issues
    By RndmNmbr in forum SprutCAM
    Last Post: 12-13-2012, 07:11 PM
  3. Lead In Lead out Speed Problem
    By JWB_Machining in forum Mastercam
    Last Post: 12-12-2008, 02:33 PM
  4. How do you mount a lead screw/lead nut?
    By jbluetooth in forum DIY CNC Router Table Machines
    Last Post: 12-01-2008, 11:10 PM
  5. lead in-lead out on surface toolpath
    By Tugiyana in forum Mastercam
    Last Post: 05-07-2007, 11:16 AM
