587,375 active members*
3,607 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > 4th AXIS STANDARD UPGRADE
    May 2013
    701
    I just added 4th axis standard and now I can't access my 3axis pro tool paths anybody else have this problem?
    Jessebobcad Guest
    I have a few questions for you:
    1. Are you able to access any 3 axis toolpaths?
    2. Are you on a machine other than Mill such as laser, plasma, or waterjet?
    3. Did you purchase the 3 axis pro module?
    To check to see if it was included on your license Click Help> License and you should see 3 axis pro with a check if it was purchased. Also, if you're not on the latest build there may be an issue. To check your build go up to Help > About BobCAD and your build number should read 996.
    Jesse
    Jesse
    May 2013
    701
    As you can see when I upgraded I downgraded must be sale dept. error
    Jessebobcad Guest
    Yep, contact the sales department.
    May 2013
    701
    The staff at Bobcad got right on this problem and took care of it. It is so nice dealing with them its like they go out of there way to get you satisfied. I couldn't be happier with the service they give. I probably didn't have over a half hour of time involved getting it resolved. And in today's world that's pretty darn good.
  1. V25 4 Axis Standard: Unwrap and Wrapping Groups
    By aldepoalo in forum BobCad-Cam
    Last Post: 02-13-2013, 12:07 AM
  2. BobCAD CAM V25 4 Axis Standard
    Last Post: 09-28-2012, 12:45 PM
  3. X5 Standard, X axis problem
    By fikoma in forum Syil Products
    Last Post: 02-24-2011, 07:18 PM
  4. standard Fanuc post 5 axis with mcamX4..ready to pay
    By jabbour in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-30-2009, 01:26 AM
  5. Could this be done on a standard 3-axis mill?
    By Fox Speedshop in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2007, 02:37 PM
