586,835 active members*
2,877 visitors online*
    Dec 2011
    12
    Machine simulation
    Hi everyone
    Need help,my machine simulation material stock not function..
    anybody can help me.
    Jul 2011
    71
    Do you have Solid Verification turned on?
    Check SolidCAM Settings>Machine Simulation>Enable Verification (it's off by default)
    Hope this helps!
    Jul 2011
    Hi Zarif,
    This is very simple,
    See picture below
Name:	Enable Stock verification.jpg
    Best Regards,
    Willian
    Dec 2011
    12
    gonfer & Aussie_CNC Thanks,now ok alredy thank you very much love u all hahah:banana:
    Mar 2011
    68
    Hello,
    Can somebody hellp me with a little problem?
    I want to simulate with stock verification in machine simulation all operations from a part, and the problem is that when I have 2 coordsys(2 origins), machine simulation is simulating the part on all origins on the same faces.
    I mention that in solid verify it is showing perfect.
    ls there any way to do something to change automatic the coord sys for real stock update in machine simulation?
    I mention another thing that if I simulate from another operation in origin 2, machine simulation is showing me the good actual stock.
    I do not use a 3d model of machine only a simple simulation.
    Wait for an answer fast as you can.
    Thanks.
  1. SolidCam Machine Simulation
    By carbide_burner in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-13-2016, 06:34 AM
  2. Looking for simulation machine models
    By montie in forum GibbsCAM
    Last Post: 01-07-2013, 08:41 PM
  3. MACHINE SIMULATION MCX4
    By dfearnow in forum Mastercam
    Last Post: 11-30-2012, 06:55 PM
  4. Mastercam X5 Machine simulation
    By IfeCro in forum Mastercam
    Last Post: 03-07-2012, 03:41 PM
  5. Machine Simulation
    By Sidni in forum GibbsCAM
    Last Post: 01-08-2012, 01:54 PM
