587,729 active members*
3,370 visitors online*
Results 1 to 16 of 16
    36
    Mazatrol Program into a G Code Program
    Can you save a Mazatrol 640 Fusion program into a "G" code program so that you can use it on another machine? Thanks.
    Mar 2004
    761
    Ask the folks at Solutionware - the makers of MazaCAM.
    I think you can import a Mazatrol 640 program into MazaCAM and export a G-Code program.
    http://www.mazacam.com/whatis.html
    36
    Have you got any idea about how much this software is? Thanks.
    Mar 2004
    761
    Sorry, I do not know the price of this software.
    Aug 2003
    812
    I got a quote last month, was about 4k.
    Feb 2005
    376
    Wierd, I just got a call from Mazacam today. For stricly Mazatrol, they said about 3.5k, and for the ability to flip and flop from g-code to mazatrol, as in program in mazatrol and post to a morei lathe or a Fadal mill (lathe and mill seperate options), 9.5k. I figure that isn't too bad, since for doing some of the simple stupid stuff on the mills mazatrol is damn quick, and if your running a bunch of lathes, I think you would be money ahead programming them in Mazatrol. Also it will, if I understand it right allow you to pull your Mazatrol programs off a Mazak, repost them and send them to any machine you want.
    No affiliation or anything, never actually tried it, but it does sound like a good idea if your running a mix of machines.
    Jun 2007
    35
    Camlink
    GriffoBros Camlink software is tailored for mazatrol programming from a PC. And will convert Mazatrol to G-Code and vice versa at the press of a button.
    Try this linh
    www.griffobros.com
    Aug 2006
    39
    I have never known Griffo Bros being able to convert Mazatrol to G-Code. Is this a new feature? Only program i have heard of and used to convert Mazatrol to G-Code is MazaCAM and it works pretty good. You dont have to buy options for printing, transfer or translation.
    Jun 2007
    35
    No, its not a new feature . We have had it (Camlink) since 1998.After you run your tool path look in the upper left hand corner of the screen and you will see ISO. Click it and you can save it to a floppy for editing or transfering.
    Dec 2005
    10
    You can use CAMWARE software from MAZAK to convert Mazatrol to EIA/ISO.
    or add EIA/ISO conversion option into your machine.
    992
    give me a buzzz if you're guys want to converse Mazatrol to ISO.
    The best way to learn is trial error.
    Dec 2007
    37
    Mazak Conversion
    Anyone know which of these programs are affordable? Or where to get a copy?
    Dec 2007
    37
    Did you find an afforadble program to convert from Mazatrol language to "G" Code? I am looking for this also. Any recomendations would be appreciated.
    Dec 2007
    300
    Smile Mazatrol G code conversion
    I use Mazacam from Solutionware Inc. It works fine for most CNC controls. Using the G code conversion from the Mazak control will not work for other CNC because it uses codes that other controls do not use. Griffo does a simple conversion to code but as far as I know it is just generic code and you have to edit it for your control before you can use it.
    Nov 2007
    13
    SOLUTION WARE WORKS THE BEST YOU CREATE THE CAD AND CAN POST
    IN MANY MACHINE CODES JUST G CODE OR TO THREE OR FOUR MAZATROL
    MACHINES.YOU CAN DO IT IN G CODE AND PRESS MAKE MAZATROL AND IT IS DONE IN ABOUT 1 SEC. SYSTEM IS A LITTLE PRICEY I THINK WE PAID
    ABOUT 18,000.00 FOR LATHE AND MILL PACKAGE
    Dec 2011
    I'm looking into moving some of the Mazatrol paths from the machines controller into an external computer we have set-up next to the machine. I would also still like the ability to send these Mazatrol paths back into the controller when needed. Does anyone do this if so what are the pro's and con's
