586,991 active members*
2,654 visitors online*
    Apr 2013
    Red face Taig Micromill 2000 and Sherline 4" rotary table with Mach 3
    I am a newbie - please help. I have set all the motor tuning in Mach 3 as per my manual (step size of 8000) but the all the axis are moving the wrong amounts. They are out by a long way. If I ask it to move 80mm it moves 32mm. It does this will all three axis x,y,z. According to the manual all 3 axis should all have the same settings as per step size. I have used the calibration option under settings but this hasn't solved the problem either. Can someone please help me. Thanks
    Apr 2004
    5742
    Are you using a Taig controller or something else to drive it? What happens if you change the steps/unit settings to 20,000?
    Andrew Werby
    www.computersculpture.com
    Nov 2009
    4415
    Are you using a metric lead or ball screw or SAE? The formula would be steps per revolution ( of the stepper) X micro stepping value X the amount of turns of the lead / ball screw per your unit of measure.
    Using a 1/4-20 as a lead screw for example takes 5 revolutions to move 1 inch. A stepper (generally 200 steps per revolution) and then the microstepping value (a G540 is set at 10x)
    So 5 X 200 X 10 = 10000 steps per inch.
    A lazy man does it twice.
  1. Taig MicroMill 2000 config
    By hamerskib in forum Taig Mills / Lathes
    Last Post: 04-24-2011, 12:33 PM
  2. Sherline 2000, need Mach 3 XML....
    By Jim Anderson in forum Benchtop Machines
    Last Post: 02-18-2010, 03:37 AM
  3. Sherline CNC rotary table adaptation
    By uptoolateman in forum Benchtop Machines
    Last Post: 02-06-2009, 09:48 PM
  4. Taig MicroMill 2000 and Mach 2, Steps/Unit??
    By JV11 in forum Mach Software (ArtSoft software)
    Last Post: 09-26-2006, 03:32 AM
  5. SHERLINE rotary table
    By ACME in forum Benchtop Machines
    Last Post: 11-17-2004, 05:15 AM
