586,817 active members*
8,274 visitors online*
Results 1 to 15 of 15
    Retrofit Spindle load meter
    Got myself a spindle load meter recently from Tormach and fitted it to my PCNC1100 series 2 over the weekend. All relatively simple as its one hole and four wires so what could go wrong.
    Well nothing I thought but when I cam to test the spindle as soon as I pressed the run switch the world came to an end and the machine took out the main MCB for the garage.
    After three hours of testing and removing and fitting wiring I came to the conclusion the VFD had blown up. So I decided to remove it to see if there was anything obviously burnt out. When I got it off I found on the bottom right is a small lever operated switch. There is no way you can see this when it’s in situ but its there none the less.
    What it’s for I am not sure but moving it earths out the VFD and I assume it’s a safety feature to release any stored energy in the VFD. What I now think happened is when I was positioning the wiring under the VFD so I could close the cable tray cover I must have moved the switch to the earthed position.
    So beware its there and just waiting to ruin your day
    Jim
    24223
    Never heard of that on a VFD before?
    What make of VFD is it? and do you have the manual that explains it?
    Al.
    Sep 2009
    624
    Al.
    The one on my 1100/II is an Emerson Commander SK, and yes, the manual is readily available online.
    Jun 2006
    2512
    As the saying goes, if all else fails read the ******* manual.
    Getting Started Guide - Commander SK:
    1.10.6 Ground leakage current
    The drive is supplied with an internal EMC filter capacitor installed. If the input voltage to
    the drive is supplied through an ELCB or RCD, these may trip due to the ground
    leakage current. See section 4.3.1 Internal EMC filter on page 16 for further information
    and how to disconnect the internal EMC capacitor.
    4.3.2 Removing the internal EMC filter
    Tab fully inserted: EMC filter fitted
    Tab fully extended: EMC filter disconnected
    Phil
    Jan 2006
    2985
    I would not expect an EMC filter to be described as a lever operated switch.
    Matt
    Jun 2006
    2512
    The filter isn't but the method of switching in or out of the circuit apparently is. It's actually a tab that you push in or out. It could be mistaken for a lever.
    If all else fails read the ...!
    Phil
    Quote Originally Posted by keebler303 View Post
    Matt
    24223
    Odd that it would trip on a MCB unless a ELCB IS being used?
    Al.
    Jun 2006
    2512
    Jan 2006
    2985
    I see the lever now from your picture. Going by your manual quote it sounded like a terminal jumper. I went to RTFM but I wasn't going to "register" just to look at a d@mn manual, that is so frustrating!
    Matt
    Jun 2005
    656
    Matt
    You can make up any fake invalid e-mail address and it will let you in. Stupid, yes.
    24223
    The bottom line is that you should be able to leave it active unless an Earth Leakage Trip breaker is used.
    Al.
    Jan 2006
    2985
    Quote Originally Posted by shred View Post
    Yes, that is what most people do, so what has the company gained by collecting a bunch of fake email addresses and customer names like swhbrwevi wrevncyubhirhy?
    Just let me see the f@#%ing manual, if I like what I see, I will buy it. I don't need a call from a numbnuts salesman to help make my decision and I don't want to receive unsolicited emails for the remainder of my natural life.
    Matt
    Oct 2011
    477
    Al.
    Would this be what is commonly referred to as a Ground Fault Circuit Interrupter (GFCI) in the US?
    nitewatchman
    24223
    Quote Originally Posted by nitewatchman View Post
    nitewatchman
    Yes.
    In some areas of the world, they are fitted as the main service breaker supplying the panel.
    Al.
    Jun 2006
    2512
    I gave up worrying about such things a while back. It's a small price to pay for access to the very detailed manuals that are available. If you own the VFD it is worthwhile having the manual. It may help you to not blow the thing up.
    Phil
    Matt
  1. Spindle Load Meter for X2?
    By sansbury in forum Benchtop Machines
    Last Post: 09-04-2013, 12:38 AM
  2. Spindle load meter
    By Selimsalim in forum Parametric Programing
    Last Post: 04-23-2013, 11:14 AM
  3. Spindle load meter
    By David Da Costa in forum Uncategorised MetalWorking Machines
    Last Post: 10-20-2011, 02:55 PM
  4. Spindle load meter
    By BJSwart in forum Haas Mills
    Last Post: 03-20-2009, 03:15 PM
  5. LB-15 Spindle load meter
    By nlh in forum Okuma
    Last Post: 10-11-2008, 11:55 PM
