587,415 active members*
3,254 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Tsugami CNC Lathe (may be PL3B) / Fanuc OT-B : Not Ready alarm? PLease Help
Results 1 to 9 of 9
    May 2011
    Dear all,
    I've bought used Tsugami CNC Lathe. But when start up, it alarm not ready like this:
    0615-09
    PMC: Z398-C
    Not Ready.
    Please show me how to solve this.
    Thanks alotAttachment 181206
ID:	181207Click image for larger version.
    Oct 2010
    131
    Hi onxious...
    the problem seems to be in PMC section of machine which consists ladder sequence/ladder logic of the machine.
    form your pic the PMC section is built in motherboard...
    the PMC data is not loading, may be because of data corrupt or EPROM failure which carries the data.
    from the details given i think you have to check with your motherboard.
    You haven't given details of the problem, try to post the pic where the alarm generates on the screen.
    May 2011
    Thanks harmeet,
    This is alarm pic
    Attachment 181212
    Oct 2010
    131
    Onxious...
    This shows there is nothing wrong with PMC.
    The machine boots up but still in emergency state.
    Check emergency circuit according to manual. Check input X21.4 which is emergency input. When emergency ckt is healthy X21.4 should be 1.
    Try to press pos button when m/c stop on this screen. It will show axis positions.
    Sent from my GT-I9100 using Tapatalk 2
    May 2011
    Quote Originally Posted by Harmeet View Post
    Onxious...
    Thanks Harmeet,
    In this screen, when I press pos button, it show axis positions but still not ready in the left bottom corner. I can't do any thing instead of viewing and changing pages.
    How can I check emergency circuit? Where is X21.4? (sorry it's new to me)
    Thanks for helping me!
    Oct 2010
    131
    Buddy...
    Check diagnosis...
    Press twice PRM/DNG BUTTON just below position button.
    1 press parameter
    2 press diagnosis
    3 press ladder logic
    On diagnosis screen check 0021
    0021 0 0 0 0 0 0 0 0
    7 6 5 4 3 2 1 0 bit
    Check bit 4 it should be 1 than machine shall get ready..
    If its 0 then you have to check in wiring manual why the circuit isn't complete.
    May 2011
    Buddy...
    Check diagnosis...
    1 press parameter
    2 press diagnosis
    7 6 5 4 3 2 1 0 bit
    I've already checked, 21.4. is 0. So I check every thing I know:
    1. Input from Oil matic for Spindle: ok
    2. Input from Oil matic for Cooling: ok
    3. Input from Automatic Lubricator: ok
    4. Emergency Stop Button in Operator Panel: ok
    5. Emergency Stop Button in Cycle Panel: ok
    But no output for Automatic Lubricator
    and I think maybe not enough Relay
    Oct 2010
    131
    Buddy check your electrical drawing.
    There will be a control ON/ MASTER ON relay. Which should be ON that will send the singnal to NC for ready.
    The machine could be in Hard overtravel. Check limit switch.
    May 2011
    So bad. I don't have electrical drawing. The machine is second hand.
    It was overtravel but I rotated 2 axis back to the middle.
    0021: 00101111
    Could you have any guide for me?
  1. Tsugami lathe conversion
    By carl bushnell in forum Servo Motors / Drives
    Last Post: 12-16-2010, 07:49 AM
  2. Tsugami PL3B Lathe start up question
    By Motopsych in forum Uncategorised MetalWorking Machines
    Last Post: 09-11-2009, 03:36 PM
  3. Tsugami PL3B Help
    By Kevin Taylor in forum CNC Swiss Screw Machines
    Last Post: 09-06-2009, 03:10 AM
  4. fanuc 0m servo not ready 401 alarm
    By keithc in forum Fanuc
    Last Post: 04-16-2009, 02:45 PM
  5. M/T Alarm on Tsugami NU4B
    By mohammadali in forum Fanuc
    Last Post: 02-01-2008, 11:00 AM
