587,189 active members*
2,724 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc o-m param diag tool changer
Results 1 to 7 of 7
    Mar 2013
    8
    first off, you guys rock ! had two vmc's, toppers with oi-m fanuc. someone changed the batteries with the power off.
    Learned on here how to reset home and clear the error alarms for xyz and was running both within an hour.
    today, an excel stallion 810 vmc with o-m fanuc, wouldn't start or move, screen and all axis were froze.
    Had no choice, under advisement, did the reset delete deal. I am nothing more THAN a newbie !
    again,axis home position was off, errors everywhere. got the parameters back in , by hand, from a back up list and the list from the manufact. now can handle xyz around, can zero out all, almost done but the changer won't change tools.
    pots will come down, changer carousel rotates, pots go up, but wont on command change.
    i loaded diag as much as i could find, all param again, to make sure. Think we're missing something. think part is the small movement the head does before it changes, off of z zero. also missing a param?
    comfortable loading the data, saving it, any ideas?
    Again, thank you all very much, You're all great teachers !
    The Less Than Newbie !
    2932
    Possibly missing the ATC macro program? The builder may be able to supply this.
    Feb 2007
    314
    any alarm when M6 is called? If it works with a tool change Macro and that one is missing, you should have an alarm 059(program not found).
    What it exactly does if you call a tool change?
    where it stole or alarm out?
    You talk about a small z movement, so your Z tool change position is not the Z home position.
    It may use the second reference point for the Z tool tool change (G30, this position is set by prm no 737 that is the distance between the first reference (Home) and the second(Z tool change)
    If it works like i suppose, you should have a limit switch to ensure that the Z axis is at the right place for a tool change. If your second reference is not set correctly, this switch could not be activated.
    All above are suppositions, more details will help to point the real problem
    Mar 2013
    8
    So far, have it where it DOES change tools as it should. i've been playin with prm 737 BUT need to reset the z home/zero. I'm trying to figure out the
    differences between the supplied manufacturers prm list and my backed up prm list. quiet different.
    thank you both for the replies so far !
    Mar 2013
    8
    OK here's an update, evidently i forgot to do the p-cancel when i started up the machine,
    i should've remember as i did a lot fixing the Topper VMC as i earlier stated.
    Changed prm 737 for the toolchange 2nd zero. Machine IS up and running no thanks to me, all thanks to
    you guys on here.
    As a little tip to others, i DID find the D- cell battery cover was missing a screw, my guess is when my guy
    shut off the machine, one of the three lost contact, next AM is when the problem showed up.
    I tested the original batteries, should be 1.5 volts, checked at 1.58 so they weren't bad, which worried me,
    thinking that was the cause.
    Wanted to make sure and post my results for info.
    Again, this site is GOLDEN !
    many many thanks to one and all.
    Mark
    Mar 2013
    8
    Looks like my post didn't show from few minutes ago, Machine is up and running no thanks to ME but all thanks to you guys and this site.
    Evidently i forgot i used -cancel-p- on start up, hence the Z zero home position kept changing, none correct. with THAT done, changed the 737 prm using the info from this site, had to be -2800 (-2.8 mm) BAMM done deal. Thanks to you all on here. What a resource.
    Was worried why this problem started to begin with, installed new D cell batteries, THIS time with power on, checked the original ones, were at 1.58 V so they weren't bad. Found the battery cover was missing a screw, the cover had to of opened enough to let one battery lose contact ...Also learned i'm going to get hard copies of all param and diag for all 10 machines !!!!!
    Jan 2019
    Dear sir, i have lost parameters and diagnostic of my excel 810 vmc with fanuc omc. Could you please send me the DIGNOSTICS and parameter of the your excel stallion 810.and tool change micro. Pl my mail id [email protected]
  1. Fanuc 18m Tool Changer Problem
    By rapitrone in forum Fanuc
    Last Post: 02-20-2013, 04:33 PM
  2. Fanuc Series18-M TOOL CHANGER RESTORE HELP
    By DALACHEAX1 in forum Fanuc
    Last Post: 09-28-2011, 09:13 AM
  3. TOOL CHANGER MACRO ENTERING IN FANUC OM
    By moghul in forum G-Code Programing
    Last Post: 12-20-2010, 03:28 PM
  4. Takisawa Mac-v4 tool changer Fanuc 6m
    By BrianM03 in forum Uncategorised MetalWorking Machines
    Last Post: 08-14-2009, 04:38 PM
  5. Kao Ming Tool Changer w/Fanuc OMC Control
    By DaveMCINC in forum Fanuc
    Last Post: 01-15-2009, 12:14 AM
