586,655 active members*
2,311 visitors online*
Results 1 to 1 of 1
    Dec 2012
    Adtech HC-6500 controller
    Hello everyone,
    I have a PCS 6 x 10 table, HT2000LHF plasma, Adtech HC 6500 controller and an HYD THC 300 height controller, SheetCam TNG, and AutoCad LT. 3/4" brass grounding rod 10' long pounded in about a foot from the table. ALL ground leads go to the rod and nothing daisy chained.
    My problem is when I begin to cut, I think i'm picking up some EMI from the HF start in my controller. I can run my nest or a single part in trial mode with no problems, only when I actually cut does the problem happen. And it's sporadic as well.
    I've been told to put low pass filters on my 220v and 110v to correct the problem.
    My question to you guys is will this put an end to my problem, and do you believe it's EMI?
    Attached Thumbnails Attached Thumbnails 20130115_113231.jpg   20130115_112340.jpg   20130130_120820.jpg
  1. what software do I need for adtech controller
    By phantom1500 in forum Uncategorised CAM Discussion
    Last Post: 06-05-2015, 10:02 PM
  2. Doosan Mynx 6500
    By daewooevc in forum Daewoo/Doosan
    Last Post: 07-19-2012, 04:10 AM
  3. No Example Files for X4 with Adtech 4840
    By scanf in forum Syil Products
    Last Post: 04-15-2011, 06:45 PM
