587,836 active members*
5,093 visitors online*
    Sep 2012
    My X700 is Doing laser And Axis Problem
    My Redsail x700 doing 2 problem 1st: Laser tube thorugh out the laser continue and 2nd: X axis is not working i m in trouble please help me now how to solve this problem ..
    Apr 2006
    108
    X-axis... Check the stepper amplifier to ensure it has power. Make sure the wires are connected properly from amplifier to the motor. Make sure wires are connected from controller to the amplifier.
    Does the motor hold in place strong?
    When telling x motor to move, does it jitter in place?
    Sorry.. I didn't really understand the first problem of yours. Can you explain better?
    Ray
    Sep 2012
    X Axis and laser problem..
    i have checked many times wires and connection they are perfect ,, Actually X axis is main problem when i push right key X axis is going to left sight and when i push left key X axis not moving to anywhere and second problem is that the laser tube has been directed means when i on the laser machine laser works automatic its through laser continue ,, when i give output then laser should work but here laser is continue throughing without any output ,,,
    Jun 2015
    Re: My X700 is Doing laser And Axis Problem
    Quote Originally Posted by m.raheel View Post
    Hello m.raheel did you figure out about x axis? i have same problem right now.
    Hi M.raheel,
    Could you tell me more details for first problem?
    For X axis ,maybe you should change some setting from control panel.
    If possible please let me know your skype ,so i canhelp you more.
    Thanks.
  1. RedSail X700 60W Laser not firing
    By ajmcmullin in forum Redsail Laser
    Last Post: 06-11-2016, 08:52 PM
  2. Redsail x700 laser
    By williamkelty in forum Redsail Laser
    Last Post: 10-23-2014, 06:03 AM
  3. red sail laser x700
    By TIMRM8100 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-12-2014, 08:20 PM
  4. x700 redsail laser cutter
    By Mannetjie Both in forum Redsail Laser
    Last Post: 03-11-2013, 05:50 PM
  5. New Laser X700 help!
    By harrison1 in forum Redsail Laser
    Last Post: 05-23-2011, 08:22 AM
