586,776 active members*
8,906 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0-T Tool wear / tool length compensation problem
Results 1 to 8 of 8
    Jan 2013
    Exclamation Fanuc 0-T Tool wear / tool length compensation problem
    Somebody, please help. We have Yang ML60-A CNC lathe with Fanuc 0-T controller from which we accidentally cleared most of the parameter data. We got almost everything sorted out except...
    We are completely missing tool wear / tool length compensation option/function. Pressing offset only brings up 'tool geometry' and 'work shift', but 'wear adjustment' is nowhere to be found! Is this a problem with parameters or something else?
    Feb 2009
    6028
    Option parameter
    Tool Offset type "B"
    Jan 2007
    243
    Not sure of the parameter but if you need some tool comp help try here: Tool Nose Radius Compensation Lathe Cam
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
    Jan 2013
    Quote Originally Posted by underthetire View Post
    Option parameter
    Thanks for the reply! I assume optional parameters are the ones from 0900 to 0920? We have the parameter table but it's lacking explanations. Could you be more specific what parameter/bits you are referring to? Everything else is working well, but this one function is causing trouble...
    Feb 2009
    6028
    Yes it's in the 900's.
    No I wont disclose option parameter number, especially not on an open forum, nor do I have the list with me.
    Jan 2013
    I had no idea the parameters are secret. Just trying to help my dad out; none of the Finnish repairmen seem to know anything about the whole issue.
    If you get the list and want to help, PM me. Thanks anyway!
    Feb 2009
    6028
    If i don't get bombarded tonight when I walk in the door, I can dig it up.
    Jan 2013
    Problem solved! We found the right parameters by doing some side by side comparison with friends Fanuc 0-T. Cheers!
  1. Tool Wear Compensation
    By tz1238 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-16-2011, 08:19 PM
  2. Tool Wear Compensation
    By rrbmachining in forum Haas Mills
    Last Post: 08-08-2011, 07:30 PM
  3. tool length compensation H registers help
    By muxster in forum Dynapath
    Last Post: 08-05-2010, 05:23 PM
  4. NEE controller with reverse wear tool compensation
    By Josh_Petitt in forum Commercial CNC Wood Routers
    Last Post: 10-26-2006, 09:58 AM
