587,043 active members*
3,155 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Vision Servo Driver Error Code?
    Jan 2013
    10
    Hi all,
    Puma 240MB ~2006
    Vision AC Servo Driver DVSD-75-14A-04
    On power up after overnight I get error code ALP-En
    Power off and power up again and the error goes away and machine runs fine.
    Any ideas?
    Thanks in advance.
    Jun 2004
    511
    Sounds like your battery is getting ready to die. You can get an single A battery holder and the proper cell at radio shack. With the power on change the battery.
    Jan 2013
    10
    Changed battery yesterday, no error this morning. Thanks!
    I'm thinking that I should probably change the battery in the CNC panel too. The manual says that I should power up the control, wait at least 30 seconds, and then turn off the power to the control and replace the battery making sure not to take longer than 30 minutes to complete the replacement.
    Notwithstanding the manual, it makes me a little nervous to pull the battery with the panel off. Can I just replace the battery with the power on?
  1. Realistic positional error for servo motor driver?
    By gavztheouch in forum Servo Motors / Drives
    Last Post: 07-26-2012, 01:56 PM
  2. Replies: 3
    Last Post: 05-18-2011, 05:26 AM
  3. 414 servo error code Bridgepoint VMC 1000
    By drchris123 in forum Bridgeport / Hardinge Mills
    Last Post: 11-08-2010, 05:42 PM
  4. Alp-Co??? Vision ac servo driver alarm
    By FBK in forum Daewoo/Doosan
    Last Post: 09-29-2010, 07:04 AM
