586,898 active members*
3,413 visitors online*
Results 1 to 20 of 38
    Feb 2007
    473
    CNC lathe scratch build!
    Hey all!
    I've been looking for a while now for a manual lathe that would suit my requirements for CNC conversion... I haven't had much luck, so I'm going to go ahead and commit to building a CNC lathe from scratch.
    Now let me just say up-front that I realize building an accurate spindle and lathe is no laughing matter... I'm treating this first and foremost as a learning exercise. If I am able to get a usable lathe at the end then great! If not, then I will investigate other options. Either way I will have learnt many things that I probably wouldn't learn during too many other projects!
    So here's the plan:
    • Scratch-built spindle with tapered roller bearings
    • 5C spindle taper with 1-3/8" spindle bore
    • 4" swing over cross-slide
    • Usable bed length of about 10-12"
    • 3/4HP brushed DC motor
    • Encoder on spindle
    • Gang tooling (I'm also sketching up concepts for a swiss-style gang lathe... We'll see about that...)
    • Ballscrews on both axes with a Gecko G540 driving 380 oz/in steppers
    Feb 2007
    473
    Here's a concept sketch for the headstock/spindle design:
    I would like to place the roller bearings closer together to minimize the loss of preload due to thermal expansion of the spindle, however I have been unable to find a ball bearing supplier online that has standard ball bearings with a 2.125" ID and 3.5" OD to match the roller bearings.
    If I can find a matching ball bearing then I will move the roller bearings closer together and then add the ball bearing toward the rear of the spindle (with a spacer between it and the roller bearings) so that the ball bearing takes most of the side-load and the roller bearings are left with the thrust loads.
    If anyone has a lead on a 2.125" ID x 3.5" OD ball bearing let me know!
    Ideally I would like the front roller bearing much closer to the spindle nose, however I have been unable to find roller bearings with and ID of great than 2.125" (at least affordably, the 2.125" ID roller bearings are $15 each...). That ID is only just big enough to accomodate the 5C drawtube (1-3/8") so the 5C taper would have to go ahead of the bearings.
    If I can find larger bearings then the taper would be able to be moved inside the front bearing and a stiffer setup would result.
    That being said I'm not hugely worried about the design as shown. It's better than a 7x12 bearing setup and roughly the same as the setup in a Sieg 10x22 lathe.
    Feb 2007
    473
    Because the roller bearings are not sealed (or even shielded) I am probably going to maintain a small positive air pressure inside the headstock by way of some small pump, as well as making tight-fitting plastic shields for the nose and rear of the headstock...
    Right now the design I see in my head is a pretty simple slant-bed gang tooled lathe. I will likely use dovetail ways instead of linear guides as I want to make as much of the lathe myself as practical.
    I am also considering whether or not a swiss-style gang tooled lathe would be practical. In this case the headstock would move along the Z axis instead of the tool slide. Adjacent to the tool slide there would be a fixed bushing which would act effectively as a follow-rest.
    This may actually be an interesting way to go because if the bushing was made removable then it could function both as a swiss-style lathe, and as a regular gang-tooled lathe. The swiss-style lathe would have the advantage of making box tools unnecessary, making tooling cheaper. It would likely be much more sensitive to variations in stock diameter though which may make it impractical.
    More to come as I continue sketching and researching!
    Jan 2012
    469
    For the spindle, you might spend some time on eBay looking for a larger lathe spindle and bearing set. I remember finding many Logan, Clausing, etc spindles with matched bearings for pretty cheap. Probably as cheap or not much more than buying a new pair of bearings!
    Feb 2007
    473
    Quote Originally Posted by TiagoSantos View Post
    Thanks for the suggestion! I'll have a look on eBay and see what I can find!
    Ebay is where I found my Logan 11 inch spindle with 5C collet adapter.
    Make sure what you look for is capable of using 5C, the Logans smaller than 11 inch can't.
    Here's some specs on Logan lathes.
    Logan Lathe Model Number Table
    Hoss
    7063
    Quote Originally Posted by aarongough View Post
    No matter what you do, the bearings at the business end of the spindle are going to carry the bulk of any side-load, and the one at the other end will be lightly loaded, unless you're working pretty far away from the chuck. In fact, most of the time, the side load on the rear bearing will almost certainly be dominated by the belt tension.
    You might also consider using a pair of angular contact bearings at the "front", and a radial or deep groove bearing at the "rear". This is a common configuration for spindles.
    I'd suggest putting a "labyrinth seal" on the front, to keep swarf and coolant out, then use shielded bearings, to help keep the grease in place. Positive pressure really should not be required.
    I would second the suggestion to find an existing spindle, it not the whole headstock. It'll be cheaper, quicker, and very likely better, than something you could build yourself. Even some of the Chinese ones are not bad.
    Ray L.
    Oct 2006
    210
    Wait for a Dunham 5c spindle block to pop up on eBay. I have bought several for 400-600. Building something will be that expensive anyway, and the dunhams have AC bearings, labyrinth seal, and a 4 degree Hardinge spindle taper for chucks. You won't regret it.
    May 2005
    3920
    You might also consider a brand new spindle.
    Here I'm thinking a replacement spindle from Grizzly or one of the other dealers. Of course is you want 5C support you would have to source a larger spindle. Another popular approach is a 5C indexer spindle for a very light lathe.
    Of course you can buy lathe spindles as block assemblies that you can bolt to your machine. Unfortunately such spindles cost more than an imported lathe. However you can always look for a used spindle assemblies.
    If you wish to DIY it isn't totally impossible you can get good results buy machining any tapers after final assembly. As for your design; for a 5C spindle you probably can do just as well with Angular contact bearings up front and a standard ball bearing at the rear. Ball bearings would allow for higher speeds which if you expect to do a lot of collet work could be advantageous. As for bearings don't get extremely uptight about having the same size at each end. In fact it would be better to retain each bearing separately. Also the front bearings need to be close to the spindle nose as reasonable. The front bearing group would be retained in place in the spindle housing while the rear ball bearing is free to move.
    For the DIY approach there is lots of info on the net. Larger spindles and housings are harder to do well. Of course this depends upon how well your shop is equipped. Further the housing is just as import as the spindle itself. Review as many designs as possible until you reach the point of enlightenment.
    7063
    You might also want to go to the ArtSoft forum, and search for a thread from a couple of years back by user Simpson36, who has built several very high performance 4th axis units from scratch. He now sells them. He learned a LOT about building high quality spindles, and his adventures could save you a LOT of time, money and effort. It's a LOT harder than it appears. I'm sure he has a thread on CNCZone as well, but I don't know where it is, or what his username is here. Steve's a VERY sharp guy.
    Ray L.
    Jun 2012
    182
    If I were building a lathe, I'd do it like this: Stepperhead
    Feb 2012
    296
    Sorry I am too busy staring at that gorgeous drawing to read what you wrote...
    You have quite the talent there!
    Feb 2007
    473
    Quote Originally Posted by HimyKabibble View Post
    Ray L.
    Hey Ray!
    Thanks for chiming in!
    Looking through some bearing catalogues I've discovered that there's a lot more options available if I go with metric sized bearings... Imperial bearings seem really sparse in comparison. It seems like if I got up to 65mm bearings I have good options in deep groove, angular contact and tapered roller all for under $60 or so per bearing.
    I understand that I would likely get a better/easier/quicker spindle if I was to buy one pre-made, however I am interested in learning more about precision machining and the 'origins' of machine precision, so I would like to go ahead with building a spindle...
    I'll have a look at labyrinth seals!
    Feb 2007
    473
    Quote Originally Posted by Winnfield View Post
    I'm sure that buying something that's known to work would definitely make life easier... But life's a bit too easy at the moment
    I would like to learn more about this kind of machining, and about machine design in general. I use a lathe almost every day so I'd like to teach myself as much as possible the important principles behind their precision.
    Worst comes to worst I end up with an expensive paperweight... Hopefully that paperweight will have taught me a lot by the end.
    Feb 2007
    473
    Quote Originally Posted by wizard View Post
    I've managed to find some inexpensive larger bearings, which means I can move the bearing mounts closer to the spindle nose.
    I'm essentially thinking that there will be a 'stack' of parts and bearings that go like this (from back to front):
    lock nuts - drive belt - spacer - deep groove ball bearing - spacer - roller bearing - roller bearing
    The entire stack would be pre-loaded by the lock nuts, but there would only be shoulders for the roller bearings... The deep groove bearing would be a tight slip fit and would be free to move when the spindle expands. Does that make sense? Does it sound reasonable?
    I'm definitely going to be doing more research on spindle design over the next few weeks...
    My shop is not equipped very well right now... But I expect to be taking delivery of a new lathe and mill within a month or so. I've put in my time making/selling pens, now I get to reap the benefits of all the crazy hours
    Feb 2007
    473
    Ray L.
    Sounds awesome! I will definitely have a look tomorrow!
    It's worth noting that I don't think this will be easy... I expect it to be a hard slog. But honestly that's actually part of the appeal. I'm ok at running a lathe now, but I expect I'll be much better when I've managed to successfully build a spindle!
    Feb 2007
    473
    Quote Originally Posted by elfrench View Post
    Looks interesting! I like the idea of having a dedicated MPG for each axis...
    Feb 2007
    473
    Quote Originally Posted by DRock View Post
    Haha, thank-you kindly for the compliment!
    My mother was a draftsman (draftslady?) for a mining company before I was born and I was making technical drawings for fun by the time I was 10 or so. This was actually the first serious drawing I've done on paper for many years, I mainly use CAD now... I still 'think' better when I'm drawing on paper though.
    Feb 2007
    473
    Thanks for all the great responses so far guys!
    The big thing I've learnt this afternoon is that bearings are much easier to get in metric sizes. I'm writing this again so that hopefully this will help someone else searching for the same information.
    I've been thinking about building a machine from scratch for many years, so I'm quite excited to have taken the first few steps, however small.
    Oct 2006
    210
    The grinding alone will cost you more than the used spindle head. These Dunham things are over 3500.00 new. You'd certainly learn a lot by taking one of them apart. They are neat. They are almost like a baby Hardinge spindle.
  1. Complete hobby build from SCRATCH, 3axis
    By lamesh99 in forum DIY CNC Router Table Machines
    Last Post: 02-23-2012, 08:26 AM
  2. Project: Aluminum Eater (Scratch Build) - New XY-base frame design!
    By LBSamurai in forum CNC Wood Router Project Log
    Last Post: 12-06-2011, 10:47 PM
  3. First build from scratch
    By Sockles in forum DIY CNC Router Table Machines
    Last Post: 08-23-2011, 11:29 PM
  4. CNC Lathe from Scratch
    By mackeym in forum Vertical Mill, Lathe Project Log
    Last Post: 06-02-2010, 12:20 AM
