586,898 active members*
2,675 visitors online*
Results 1 to 12 of 12
    Jul 2007
    675
    Mach3 Feed Hold Error
    All,
    Like many of you, I've been a Mach3 user for years. Recently, whenever I hit "Feedhold" and then "cycle start", mach3 sends the machine to the tool change position (X0 Y0 Z4) . Has anyone seen this before? Attached is the gcode file when it occured.
    Thanks!
    Here's My Config:
    Mach3: version 03.043.066
    OS: Windows 7
    Screenset: MachStdMill
    Plug-in: VistaCNC iMachIII P1A pendant
    Attached Files Attached Files
    Jun 2007
    3734
    My guess is it only happens in the drill cycles.
    Try removing the G98 from the drill cycle lines.
    I guess that what it does in a drill cycle, and acts like you reacted to a broken drill.
    What's with all the G90's. There is never a G91 to cancel. Just one at the start of the program would suffice.
    Jul 2007
    675
    Thanks. I'll fix that, but this error happened during the profile portion when I hit feed hold.
    Jul 2007
    675
    Not Solved!
    I edited the GCode as advised bu it didn't fix the problem. I reverted back to an old version of Mach3 (R3.042.020) adn the problem did not occur.
    Is anyone else having feed hold or stop problems with 03.043.066?
    I hope I'm not the only one
    Jun 2007
    3734
    I don't use the latest version of Mach3 because it did strange things.
    Jul 2007
    675
    What version are you using
    Jun 2007
    3734
    A really early version that doesn't have 2 separate slider for the feed!! Licensed 2.63 I just looked. Just because it has always worked, and is not broken.
    I did one 800 hour job, and didn't want any surprises.
    I do have 3.043.022 but every time I try to move forward, I step back and read the revision information, and there is no gain for me.
    I never upgrade stuff without a reason, and surprise-surprise - not to many unwanted 'features' surprise me.
    Am I getting older and wiser? Nah, not possible.
    Dec 2011
    316
    MRM
    Check out MSM board. Dave has posted various issues with each Mach version. I remember something on this one.
    JOhn
    Jun 2007
    3734
    MSM board? Do you have a link please John.
    Dec 2011
    316
    Link to support forum:
    Calypso Ventures, Inc.
    From the release notes (Applies to LATHE) but maybe there is a Mill issue as well.
    4.47 Lathe: Resume from FeedHold Causes Machine Crash
    There is a very serious bug that causes Mach to crash a machine (does multiple uncommanded
    moves and runs tool thru part).
    WARNING: DO NOT USE FEEDHOLD for Lathe in mach 3.43.56 thru 3.43.59!
    This was apparently a side effect of a prior change to mach.
    Probably broken in 3.43.56 (Dec 27 2011)
    Verified broken in 3.43.59 (Mar ?? 2012)
    Fixed in 3.43.62 (Mar 31 2012)
    Might be worth a post on the MSM board to see if anyone is aware of this.
    John
    Jul 2007
    675
    John
    Thanks John! I reverted to 3.43.58 and all seems to be well. Version 3.43.66 would lock out the keyboard, crash at random times, in addition to the feedhold anomaly (in my case).
    I'll let you guys know how it goes.
    MRM
    May 2014
    Re: Mach3 Feed Hold Error
    I have a simillar problema I have the MACH3 Version R3.043.022 when I use FeedHold during an arc cutting and then restart with cycle start the MACH3 just won´t go back to the following coordinate, only when I push the FeedHold on my computer where I simulate the cutting path, but when I go to the machine it does something similar but only on straight lines, I don´t know what is wrong, can anyone help?
    I cut EPS Foam, I only use 2 axes (X,Y) with the MACH3, and I use cutting wires instead of tools.
    Here in my program
  1. mach3 lathe feed hold
    By bcox0_0 in forum Mach Lathe
    Last Post: 09-20-2013, 10:51 PM
  2. Feed Hold during M80 command
    By Nation in forum Haas Mills
    Last Post: 11-05-2012, 10:03 PM
  3. feed hold switch for mach3 software
    By rotsenmendoza in forum Mach Software (ArtSoft software)
    Last Post: 03-01-2011, 03:57 AM
  4. Feed Hold
    By HelicopterJohn in forum Haas Mills
    Last Post: 04-25-2008, 03:57 AM
  5. What should Feed Hold actually be??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 01-22-2006, 07:04 PM
