587,308 active members*
3,545 visitors online*
    Dec 2012
    Gundrilling coolant
    Hi, We do a lot of gun drilling on a large horizotal Makino machining centre and on CNC lathes. size ranges from 4mm to 20mm and sometimes 500-600mm deep. we are using high pressure coolant pumps. We have looked at different soluable coolants but was wondering if anybody has experince with coolants and can recomend some. We also gundrill Berryluim copper but only short deeps but use the gundrills for finish.
    Apr 2002
    5003
    All people who gundrill I know, useing only non soluble coolants with hp detergents. Its better for the tool, the workpiece, the machines. But a hp oil is much more expensive than a water soluble cooling. And you need a mist exhaustion and fire extinguisher into the machine.
    Mar 2006
    2712
    I operated a gun drill a loooong time ago. We used sulfurized HP oil. That stuff stinks!!!!!
    I would think there are better gun drill coolants available now. I would contact Trim Chemical or some other well established supplier and see if they have something for you.
    I know the suppliers have done wonders for grinding coolants.
    Dick Z
    DZASTR
  1. Coolant must go - Going DRY
    By Magnum164 in forum Tormach Personal CNC Mill
    Last Post: 03-17-2011, 05:39 AM
  2. Coolant
    By coolantman in forum News Announcements
    Last Post: 03-24-2009, 02:13 PM
  3. Coolant Pan
    By BlueFin in forum Tormach Personal CNC Mill
    Last Post: 01-26-2009, 03:26 AM
  4. Can anyone tell me about this coolant?
    By alexccmeister in forum MetalWork Discussion
    Last Post: 10-15-2008, 10:49 AM
  5. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
