586,588 active members*
2,599 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > ADT-CNC4640 4 Axis Milling CNC Controller
    ADT-CNC4640 a 4 axis CNC controls are designed for Milling/Drilling, adopt ARM9 high performance CPU and super-lager programmable FPGA, real-time multi-task control technology and hardware interpolation technology. Guaranteed the efficiency of μm-level precision processing. 256M electronic hard drive, satisfying the processing of wordpiece with all kinds of large programs, 7 inch color display screen.
    Function:
    CNC System Function
    Self-diagnosis
    Diagnose CPU, memory, LCD, I/O interface, parameter state, coordinates and processing program comprehensively every time the system is started or reset; diagnose power supply, principal axis, limit and I/O ports in real-time during operating.
    Compensation
    Automatic reverse clearance compensation
    Automatic tool length compensation
    Automatic tool radius compensation
    Automatic tool radius biasing and automatic tool tip transition
    Abundant instruction system
    Scaling instruction
    Mirror processing instruction
    Tool biasing instructions
    Program cycle, program skip, program shift, program transfer, different end processing modes, macro definition and program management instructions
    Fixed-point instructions: starting point, setting point, etc.
    Linear, arc and spiral interpolation instructions
    Six workpiece coordinate systems, nine extension coordinate systems and one reference point
    Full English menu operation & full screen edit
    4640/4620 CNC control system uses cascading menu structure and full Chinese operation to ensure simple operation and visibility.
    Abundant error-correction functions
    Point out the nature and correct the errors in operation.
    Program exchange between CNC system and PC
    Perform CAD/CAM/CAPP auxiliary programming with abundant software in PC, and then transmit CNC program to the system through communication interface (USB disk, RS232 interface), or transmit the programs from the system to PC.
    The leading manufacturer of total motion control solution
    Sep 2004
    10
    Quote Originally Posted by adtechcn View Post
    I have CNC4620. Why no have any CD or DVD software in a box? Can you send to me via email.
    hi, friend, Which country are you from? If you bought it from China directly, please contact our salesman, if you purchased it from our agent, please contact your local agent. Thank you.
    Sep 2004
    10
    Thailand dealer say "ADTECH no plan to use with RS232/LAN. And please use front USB only".
    And many bugs in ADT CNC4620. I'm report to him for solve problem. No respond.
    Dec 2012
    22
    Any tutorial videos for the cnc4640, just bought a syil x7 fitted with one in Australia. New from dealer.
    Sent from my GT-I9100 using Tapatalk 2
    You can ask our agents to get tutorial videos for the cnc4640 .
  1. 4 Axis High Grade Milling/Drilling CNC Controller
    By adtechcn in forum News Announcements
    Last Post: 10-24-2012, 11:03 AM
  2. 3 axis CNC controller kit 3 NEMA17 78 oz-in stepper motor + 3 axis CNC board
    By Chaparro1973 in forum Stepper Motors / Drives
    Last Post: 03-12-2012, 10:26 AM
  3. milling parameters for t2 controller
    By Jfrahm in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-18-2010, 09:23 AM
