587,874 active members*
3,538 visitors online*
    Oct 2006
    69
    Z axis problems
    I'm using Mach 3 with a 4 axis Gecko drive. When I use the keyboard to jog the machine on the Z azis only it will reverse itself (pg up sends carriage down and visa versa). It is not consistent. If you tap the keys it will reverse itself again. I've reinstalled Mach 3 and changed the keyboard with no help.
    I'm praying it's not the Gecko drive. It does not happen on the X and Y axis.
    Thanks in advance.
    Try increasing the pulse widths in the motor tuning to around 10. If that doesn't help, you may have a weak parallel port.
    Oct 2006
    69
    Found the problem. swapped the y and z cables and y acted up, z was ok. That told me it was in the z cable. Opened it up and 2 wires were lose from the solder joints. Works fine now. Thanks for the help.
    Aug 2012
    swap cables as you did for example sometimes can easily solve your problem. You swap the cables Y and Z, if same problem happened on Y it meas your cable or driver has something wrong .
  1. Dual Y Axis Slave A Axis Homing Problems
    By guy2b1 in forum Calibration / Measurement
    Last Post: 03-03-2012, 11:06 PM
  2. y axis problems
    By ian12 in forum Techno CNC
    Last Post: 01-08-2012, 09:45 PM
  3. help please 3 axis problems
    By capital in forum Fanuc
    Last Post: 09-20-2007, 03:55 PM
  4. 4th axis problems II
    By little bubba in forum Fadal
    Last Post: 10-24-2005, 01:13 PM
