587,482 active members*
3,543 visitors online*
Results 1 to 11 of 11
    Mar 2005
    816
    Operator Panel Connection Unit
    I'm having a couple problems with my operator panel on the Series 15.. and found I have in stock a couple different units.
    They are marked A02B-0094-C107 and also there is a -C108 too. The A02B-0094 being the Series 15 installation number.
    They're nearly identical, but they have the following boards:
    A20B 1003 0630
    A16B 1212 0300
    A16B 1212 0301
    The only difference being the A16B-1212 boards.
    I have never seen these referenced. So.. can anyone tell me the difference?
    I use the Series 15 operator panel for this one, it's a bit like the NA Op Panel, previously used my FS0C full keyboard operator panel.
    Feb 2009
    6028
    Those could be for the fanucs fapt option. There were additional cards for graphics. Only a guess though.
    Mar 2005
    816
    No not graphics.. the graphics board is on one of the masterboard / backplane boards. The boards I'm talking about are part of the i/o chain that go to the operator panel, not the crt/mdi.
    Apr 2009
    1379
    A16B 1212 0300 DI/DO = 96/64
    A16B 1212 0301 DI/DO = 64/32
    A20B 1003 0630 power supply
    Mar 2005
    816
    Oh yeah, that's it. Is that the I/O power supply too? I use the 44C74xxxx or 44A74xxxx type operator panel for the Series 15 as in the FANUC document GFK-0720
    There's 4 blue honda connectors on this board. Where do they go to? what about the other brown Burndy connectors?
    Attached Thumbnails Attached Thumbnails A16B-1212-030x board.JPG   a02b0094c108.jpg
    Apr 2009
    1379
    I think that is only for the I/O.
    Some more info in gfz-61213 (connection manual)
    Mar 2005
    816
    That's a manual I don't have for the series 15 model A. All I have is the operator manual and the maintenance manual. Did you get my email with the parameters?
    Apr 2009
    1379
    Did not get the list.
    I have a spare manual, but is fairly heavy to ship.
    Can you buy it on ebay?
    24220
    I have a set for the 15 if you want to PM me an email add.
    (In PDF)
    Al.
    Mar 2005
    816
    Ok. Yeah I prefer scanned / pdf manuals. Mine is a model A not B. I have the B model manuals.
    Pm sent.
    Mar 2005
    816
    I don't know why it quit working, but I've since the build was completed changed op. panels from a older style to the series 15 op. Panel that is much like the i series / north America op. Panel.
  1. Series III Operator Panel
    By GLCarlson in forum Tormach Personal CNC Mill
    Last Post: 04-07-2012, 05:47 AM
  2. Relocate Hass TM-2 operator panel .
    By tafc in forum Haas Mills
    Last Post: 03-14-2011, 09:42 PM
  3. Accessing Software Operator Panel Oi-TC
    By adamant in forum Fanuc
    Last Post: 02-26-2011, 07:44 AM
  4. Mazatrol T1 Operator Panel Problem
    By mattme in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-26-2010, 12:44 AM
  5. CNC Operator Panel Design
    By Al_The_Man in forum DIY CNC Router Table Machines
    Last Post: 09-13-2004, 06:03 PM
