586,500 active members*
2,869 visitors online*
    Jul 2003
    53
    What are your rapid speeds?
    I have a KT 25-14 with .200" pitch screws. I'm running a Gecko 540 driving Keling KL23H2100-35-4B stepper motors and using Mach 3 as the controlling software. I'm curious to know what other people are getting for rapid speeds who are using similar configurations. The fastest I seem to get is 75 i.p.m. before the motors stop turning and emit a high pitch squeal. Is that about par with everyone else?
    Jan 2011
    27
    Mine's a 3925...don't know the screw pitch details. Rapid is about 115.
    Jul 2003
    53
    Thanks Cr2. Anyone else care to share?!!
    Oct 2008
    2100
    Not a K2CNC machine, but...
    I've got a cheap Chinese router with ball screws. It sitting behind a Smooth Stepper and a G540 with whatever those 382 oz motors Ahren sells are on the screws. After I put in the SS I tested to well over 600IPM, but had some reliability issues with position during torture testing. I turned it down to 300IPM on X & Y and 150IPM on Z and it seems to be pretty good, but I have not run any long jobs on it since. I do have accell/decell set fairly conservatively, and it takes some distance to get upto that 300 IPM top speed.
    To be fair though doesn't the K2CNC come with acme screws and Dumpster CNC style acetal antibacklash nuts.
    I have a small box way mill with similar leads (retrofit) and the fastest I could run it without stalling or binding was about 80 IPM. (Straight parallel port no Smooth Stepper)
    Bob La Londe
    http://www.YumaBassMan.com
    Jan 2011
    27
    The K2 3925 has zero backlash ballscrews.
  1. ipm of rapid
    By pjb1967 in forum Fadal
    Last Post: 03-09-2012, 05:47 PM
  2. rapid
    By hansunhan in forum News Announcements
    Last Post: 07-23-2011, 04:14 PM
  3. feed override and rapid speeds
    By rkremser in forum Mach Mill
    Last Post: 02-03-2009, 03:04 PM
  4. Getting Bobcad to not use G00 rapid.
    By joefox in forum BobCad-Cam
    Last Post: 10-13-2008, 02:08 PM
  5. How to figure rapid speeds
    By Hack in forum Linear and Rotary Motion
    Last Post: 09-06-2005, 01:31 PM
