586,690 active members*
3,063 visitors online*
    Dec 2011
    Tailstock Low
    I've got a Shoptask Eldorado ~2003 model. I'm trying to get it all tuned up to convert to CNC. Like the rest of these machines the quality is lacking... I first noticed that when drilling with the tailstock the drill bits would deflect.
    As shown in the first 2 pictures I've got two centers mounted and the tailstock is low. I've got the ruler in there, but it is even visible with my uncalibrated eye.
    I saw this forum or another forum about someone else having this issue. For the life of me I can't remember what the fix was.
    My first thought is to figure out exactly how low it is and shim under the 4 bolts between the lower and upper half of the tailstock as shown in the 3rd picture.
    Its this a good way to fix it? What would be the best way to measure how much it the tailstock is low?
    Attached Thumbnails Attached Thumbnails IMG_1348.JPG   IMG_1349.jpg   IMG_1350.jpg
    Dec 2007
    413
    The first thing you need to check is if the tailstock barrel is travelling parallel to the ways- on those machines with the combo tailstock/ steady rest, any contamination- even paint between the surfaces can cock the assembly and cause the barrel to travel at an angle.
    That can cause it to be off in a number of directions. If the barrel is travelling straight and parallel to the ways, then you will need to shim the upper half to raise it up. This is a lot easier than trying to lower one that is too high. Just measure the error and find some appropriate shim material to put between the two parts.
    2010
    Make sure that the cutting edge of a tool in the slide is on center with the center in the headstock. Then use the tool edge to compare to the tail stock center extended and retracted. This will tell the story if it is high or not traveling parallel.
    “ In questions of power, let no more be heard of confidence in man, but bind him down from mischief by the chains of the Constitution.” Thomas Jefferson
    Dec 2011
    I found that it was not traveling parallel. It was about .010 low. total and .004" over the 3" of the tail stock travel.
    I was able to get it to travel parallel with in .001" over the ~3" of by shimming .004 under the left side of the tail stock. It isn't perfect, but way better than it was. The last 1" for so has a .002 dip in it.
    There was also the annoying yellow paint between the bottom and top parts of the tailstock. I don't think this was allowing it to be torqued down evenly contributing to the total error. It is much better now.
    Taking all of the tailstock apart required me to re-align the horizontal axis as well.
  1. HIT-18S, need help with tailstock
    By BNR_RANDY in forum Hyundai Kia
    Last Post: 03-17-2018, 12:13 PM
  2. Anyone used sub-spindle as tailstock?
    By TonyW in forum Okuma
    Last Post: 09-01-2015, 06:29 PM
  3. tailstock
    By guydrisc in forum Okuma
    Last Post: 10-24-2009, 08:13 PM
  4. sl-30 tailstock
    By travis1 in forum Haas Lathes
    Last Post: 11-04-2008, 05:32 PM
  5. TL-2 tailstock
    By rbest27 in forum Haas Mills
    Last Post: 11-11-2006, 12:20 AM
