587,012 active members*
3,626 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Z-axis plunge movement question
Results 1 to 5 of 5
    Jul 2012
    I was cutting my first part this weekend and I couldn't help but notice how slow things were moving because of the plunge rate.
    Basically I set the plunge rate low because I was working with a 3/16 end mill and deep pockets. The problem is I take a pass and then Z comes back to the original height..well after a few passes its taking minutes to get to material.
    Would like the plunge to be fast until it reaches a certain distance..seems the software should be able to calculate that and reduce machining time.
    Apr 2003
    178
    Hi Dan-
    I will probably do something like what you've mentioned at some point but there's nothing in there to handle it now. I've stuck with the current system for a while because it's "safer" in the face of some of the very difficult models that MeshCAM gets (regular pockets are easy but the more organic 3D models can be MUCH more difficult).
    It's not a short-term change but I'd like to get to it in a future release.
    -Robert
    Jul 2012
    Thanks for feedback Robert. I imagine the programming would be involved in order to insure safety...fun stuff to sift through though.
    My backup plan is to hand edit the gcode once I'm happy with the part.
    Jul 2010
    567
    Quote Originally Posted by robgrz View Post
    Hi Dan-
    -Robert
    Your program is the only one that handles what I throw at it
    Apr 2003
    178
    Thanks JM- I love hearing that.
    -Robert
  1. Roughing waterline plunge question
    By beanbag in forum SprutCAM
    Last Post: 11-22-2011, 06:49 PM
  2. Putting together Taig mill, question about Z axis movement
    By DE001 in forum Taig Mills / Lathes
    Last Post: 03-13-2010, 09:18 PM
  3. Tool diameter/ipm/plunge rate/etc question.
    By QSPSB in forum Benchtop Machines
    Last Post: 01-18-2010, 09:34 PM
  4. Plunge rate in Sheetcam question
    By plain ol Bill in forum Waterjet General Topics
    Last Post: 10-02-2009, 11:48 PM
  5. Just a question about plunge milling.
    By Machine1 in forum Hard / High Speed Machining
    Last Post: 01-29-2004, 03:36 AM
