So, for over a year now I've owned a FSE "40" watt glass tube hobby laser. (I say "40" because I truly dont believe this thing is 40 watts - given other posts in the FSE subsection threads). I've used it mainly to cut cardstock, but I've also manufactured some items like acrylic keychains, wooden boxes, and I've made good money engraving pet ID tags at dog-themed events.
I've never been thrilled with the laser. It always seemed like it couldnt pull off the resolution it promised. I know anodized aluminum is one of the best things to engrave as it really holds up to whatever resolution you throw at it.
One issue I've had is with the tags I use, some of them, for reasons I cannot understand, some just do NOT engrave well. They are streaky. Funny thing is, it's some colors that are worse than others. I was doing an event with some new diamond shaped tags, and someone thought it looked like the Superman symbol, and wanted a "P" on it. Well, it engraved like crap. Something I'm sorta used to. (Again, not all the tags did this, just certain colors. The ones that DID look ok, the resolution was always a little... less than desirable, but, hey, it worked well enough!)
Here's what they looked like:
So I recently get my Universal Laser Systems 50 watt desktop model. Without playing with any settings whatsoever, I take one of the "bad" tags and pop it in, and try and engrave the bottom half of that image again.
And lo and behold:
I dont know if it's the electronics of the glass tube, if it's the fact that the thing is NOT firing at a full 40 watts, if it's the cheap chinese lenses - I dont know WHAT the problem is, but on some colors I could never get my FSE to engrave on that correctly. Without any adjusting, the RF tube laser worked.
All I know is that yes, FSE's machines are a lot more affordable, but I'm sold on the RF tube lasers for life. There's just no comparison.
