Hey all!
I've finally setup my mini lathe, and have spent the last few days getting to know it... Unfortunately I've noticed one major issue:
Whenever I take a cut, the depth of cut varies slightly (maybe a couple of thou) depending on the handwheel position. So I end up with a slight wave pattern on the work that corresponds with the handwheel position. It seems like the carriage is rocking slightly when I am applying pressure to turn the handwheel.
I have already adjusted the carriage strips to the point where any tighter and the carriage will bind in place.
I'm thinking this might be related to lack of a proper oil film on the ways (I don't seem to be able to oil it so that the carriage leaves an oil film in it's wake, it seems to scrape the ways clean of oil instead).
I also seem to be unable to get any sort of decent surface finish when turning the OD of a part. Facing cuts are beautiful and clean, but as soon as I move to the OD I get a scraped, gummy looking appearance marked with bands.
It might be worth mentioning that the ways on this lathe are somewhat crappy. I checked them with the edge of a good 6" square and there was light showing through all over the place. The dips didn't seem to correspond with any marks on the work though.
Any advice will be well received!
