587,480 active members*
3,339 visitors online*
Results 1 to 7 of 7
    Jan 2008
    4
    Just got a 7x12 Homier lathe
    A friend just gave me a Homier 7x12 lathe with extra chucks, tools, holders, etc.
    And I've used it already to make several small fixes out of wood & plastic.
    Is there a small milling attachment made a lathe of this size?
    Thanks,
    HW
    Nov 2005
    655
    Walking is highly over-rated
    Jan 2008
    4
    Thanks for link: RE milling attachment
    Thanks,
    I saw one similar to that on http://www.lathemaster.com
    HW
    Jul 2005
    442
    Pick up a cheap angle plate and mount your compound to it - you can then use the lathe to machine a vise mounted the compound
    http://www.use-enco.com/CGI/INSRIT?P...PMAKA=418-4315
    Aaron
    Jan 2008
    4
    Milling attachment
    Thanks for the angle link.
    Hey, that's a good idea. I have an extra compound. I could mount that to the vertical side of the angle as the z axis. And if I mounted a small machinists vice to the compound as a work holder? I'd have a simple milling attachment.
    I can use the picture on "littlemachineshop" as a guide.
    Thanks,
    HW
    Jul 2005
    442
    A block of steel would work as an angle plate if you have the right size.
    I looked into doing this but found the X1 micro mill on sale for ~$230. Now that the X1 is pushing $300, the X2 from Cummins ($399) is a better deal on a mill.
    Aaron
    Jan 2008
    4
    Milling attach
    Thanks,
    Have no steel block, but that angle is cheap and I can work with that.
    Thanks again for your help & ideas.
    Herb
  1. 4 or 5" 4-jaw chuck for 7x12 mini lathe.
    By Deviant in forum Mini Lathe
    Last Post: 03-07-2008, 09:44 AM
  2. looking for a 2 axis controller for 7x12 lathe
    By nymachinist in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2006, 04:00 AM
  3. Mini Lathe - Homier
    By JFettig in forum Mini Lathe
    Last Post: 02-20-2004, 09:58 PM
  4. Should I get a homier 7x12
    By WOODKNACK in forum Mini Lathe
    Last Post: 04-12-2003, 05:42 AM
  5. Homier 7x12
    Last Post: 03-18-2003, 06:04 PM
