587,006 active members*
3,206 visitors online*
Hybrid View
    Jun 2012
    Change Mechanical Orientation?
    Hi all.
    I have a Guangdaly CNC machine with NC studio as the program.
    Is there any way I can change the mechanical orientaion so the zero point is at the direct diagonal opposite? So the starting point is directly opposite?
    Any into would be greatly appreciated.
    Sep 2010
    If you were using Mach3 to drive it, just set your zero position to the other corner then change the motor step direction on the Motor output pins. I am only a novice myself, but I would think that would swap everything around. I presume NC Studio has something similar. Try without a tool first.
  1. Interact 720x tool change/spindle orientation
    By Yorkshire Chris in forum Bridgeport / Hardinge Mills
    Last Post: 12-14-2011, 03:33 PM
  2. tool change orientation
    By slowlearner in forum Cincinnati CNC
    Last Post: 12-02-2011, 11:07 PM
  3. Spindle orientation prob during tool change
    By CRABMAN in forum Cincinnati CNC
    Last Post: 01-25-2010, 07:55 PM
  4. How to change default xyz orientation
    By RaveBoy10 in forum Solidworks
    Last Post: 03-24-2008, 01:35 AM
  5. How to change imported part orientation
    By RaveBoy10 in forum GibbsCAM
    Last Post: 03-17-2008, 02:55 PM
