Hi All,
I was about to start cutting a few jobs after a lay off of about 3 months, when I last used the machine it worked perfectly.
I am now having problems
1. When I plug in the USB lead the control card is throwing up a "not recognized" in the device manager.
2. When I draw a part in LaserCut 5.1, calculate the cut file then export to the usb flash drive, download it to the machine the file is loaded, when I press start the display says contouring but the X & Y don't move.
If I press the escape key on the pad I can manually move the axis' anywhere on the worktable.
If I then press datum it moves both axis's to the 0,0 datum position & holds the position after touching the limit switches with a slight recoil of approx. 2mm X & Y.
Any idea's I'm at my wits end.....!!!!!!!!!!
Rich
