587,832 active members*
3,488 visitors online*
Results 1 to 7 of 7
    Jan 2006
    19
    Lost control, XYZ-1280 Leetro MPC 6515 board.
    Hi All,
    I was about to start cutting a few jobs after a lay off of about 3 months, when I last used the machine it worked perfectly.
    I am now having problems
    1. When I plug in the USB lead the control card is throwing up a "not recognized" in the device manager.
    2. When I draw a part in LaserCut 5.1, calculate the cut file then export to the usb flash drive, download it to the machine the file is loaded, when I press start the display says contouring but the X & Y don't move.
    If I press the escape key on the pad I can manually move the axis' anywhere on the worktable.
    If I then press datum it moves both axis's to the 0,0 datum position & holds the position after touching the limit switches with a slight recoil of approx. 2mm X & Y.
    Any idea's I'm at my wits end.....!!!!!!!!!!
    Rich
    What operating system Rich?
    cheers
    Dave
    Jan 2006
    19
    Hi Dave,
    Computer is Win 7 but I run it in compatability mode for XP SP3.
    Rich
    Nov 2010
    787
    LaserCut 5.1 ??? Why?
    You should use LaserCut 5.3 with MPC6515.
    CNC lasers, constructions, service
    Jan 2006
    19
    Ok,
    Got the machine working in stand alone mode, I reloaded the firmware & cfg file from LaserCut5.1.
    Didn't know laserCut 5.3 was available.
    Downloaded LaserCut 5.3 from the Leetro website, changed the dll files to suit the firmware all seems Ok in stand alone mode.
    Still having trouble getting the machine to link with the USB lead, windows is saying device not recognized, the printer lead works fine in another printer so can rule out the lead.
    I'm suspecting a problem with the MPC6515 main board.
    Any other ideas I could look at.
    Rich
    Nov 2010
    787
    I would try real XP.
    Jan 2006
    19
    I could do that, the anoying part is, it has worked perfectly in compatability mode until quite recently.
    That's my last resort.
    I have another PC running real XP for my other CNC machines, I will load LaserCut 5.3 on that & give it a try.
    Any more ideas if that doesn't work.
    Thanks for the advice :cheers:
  1. CO2 Laser with Leetro 6515 - Software problems
    By crocketman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-14-2017, 07:16 PM
  2. Suke Laser 1280 on the way
    By pete00 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-28-2012, 03:23 AM
  3. MPC 6515 and Lasercut 5.3
    By vlada2 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-17-2010, 08:07 PM
  4. LinkMotion and Leetro 6515 CO2 laser controller
    By cncadmin in forum News Announcements
    Last Post: 06-09-2009, 04:27 AM
  5. Lost in space - Isolation Board??
    By CPierce18 in forum DIY CNC Router Table Machines
    Last Post: 08-11-2007, 06:13 PM
