586,912 active members*
3,358 visitors online*
Results 1 to 4 of 4
    Mar 2008
    15
    Powerpath 15 Programing , bar puller
    I've had two of these lathes for quite a few years now. One with a air bar feeder and one setup as a chucker. I set the chucker up with a bar puller today and got it to work, but I'd like to get the machine not to do it in rapid feed rate. When I enter g code into the program(G95) feed per min and use G1 with a feed rate the machine won't allow it without the spindle turning. I can't pull the bar that way. Has anyone out there used a bar puller with powerpath 15 (dx32 control) and programed the machine to move without the spindle turning.
    Thanks, David
    Mar 2008
    15
    My Error
    It was a simple error in my programing.... I mixed up G94 and G95 in the program.
    G94 is inches per Min and G95 is inches per Rev.
    Oct 2005
    17
    Re: My Error
    I am about to try a puller on my powerpath. Did you have success? What type of puller are you using?
    Mar 2008
    15
    Re: worked out fine
    It worked out fine. I bought a puller from someone on Ebay. It is a three craw puller that is adjusted with spring pressure. Only negative comments would be that the your stock has to be extended further from the chuck at cut off to leave enough material to grab with the puller. I like using the air bar feed on my other machine with a collet chuck better.
  1. Powerpath 15 threading problem
    By joatace in forum Bridgeport / Romi Lathes
    Last Post: 02-03-2023, 01:33 PM
  2. Online cnc programing/ offline cnc programing
    By grimantas in forum Polls
    Last Post: 11-28-2012, 02:03 PM
  3. I need maintenance manuals for my Powerpath 15
    By Interact77 in forum Bridgeport / Romi Lathes
    Last Post: 12-28-2011, 01:15 AM
  4. Bridgeport powerpath 15
    By Nadda` in forum Bridgeport / Hardinge Mills
    Last Post: 01-06-2010, 06:22 PM
