586,556 active members*
3,359 visitors online*
    Apr 2010
    363
    Hitachi X200 VFD Questoins
    Hey,
    I just purchased a Hitachi VFD to go with my 3kw Chinese spindle. I went with the 10HP model which can run on 1 or 3 phase. The spindle is de-rated 50% since I am running a 4.3ish HP motor on single phase input.
    Anyways, I set all my settings (well, maybe not all of them) and can get it to spin if I give it little help to get started. I can get it to spin either way. Without giving it a push start it will just sit and hum. Does anyone know what is going on? Hours of google turns up nothing. Any help would be greatly appreciated.
    Alex
    Dec 2010
    634
    Post your settings for the VFD.
    How fast does it spin?
    The key parameters to look at are:
    Base Frequency - probably either 300 or 400Hz basically your max speed
    Run Frequency - set to your max for testing
    Max Current - set to your spindles max current - a little safety buffer
    Number of poles - again, match your spindle.
    Ramp time - 5 seconds ought to do it.
    As a total guess, your base and run frequencies might be set so low that your spindle won't turn.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
  1. HITACHI X200 settings
    By 15mgtar in forum DIY CNC Router Table Machines
    Last Post: 03-29-2015, 12:48 AM
  2. Hitachi X200 and 2.2kw spindle issue
    By henrikm in forum DIY CNC Router Table Machines
    Last Post: 03-18-2012, 01:57 PM
  3. Hitachi X200 OPE-SR keypad
    By KEYTEEM in forum Phase Converters
    Last Post: 01-15-2012, 03:31 PM
  4. Hitachi X200-022NFU Power Requirements
    By Kent23 in forum Phase Converters
    Last Post: 09-29-2010, 04:36 AM
  5. Hitachi X200?
    By fritts in forum Phase Converters
    Last Post: 12-27-2008, 04:06 AM
