587,887 active members*
3,243 visitors online*
    Mar 2010
    59
    Problem cutting circles
    I have a sx3 with the cnc fusion kit. When I cut inside profile circles, instead of cutting one continuous circle it stops four times. As if it's dividing it into four arcs. I'm using cut2d and Mach 3. Also, somehow my machine got put on cv mode and I don't know how that happened. Is there any other way to change the mode without going into the settings?
    Thx,
    Rod
    Mar 2010
    59
    Anyone??
    Feb 2007
    664
    In the x,y plane
    When cutting a circle their is four axis reversals, two for x, two for y
    My guess is you are seeing the machine adjust for backlash at each axis reversal
    Mar 2010
    59
    That makes perfect sense. Thx!
    Sep 2013
    5
    Hi, I also have an SX3 that just recently converted to CNC and am seeing the same issues with circles (arcs), I don;t know if it is a mechanical issue or a Mach3 issue. The tolerances between the straight contours in some of the pockets are good +/- 0.02mm but when it comes to doing circles, arcs, ellipses or anything round there is something really wrong. The error seems to be symmetric or when there is a change in direction but in different quadrants (1-3 or 2-4), I replaced the stepper couplings to helical zero-backlash with no luck, still see the same issue.
    Please any recommendations??? I have attached photos.
    Attachment 214986
    Attachment 214988
    Attachment 214990
    Attachment 214992
    Attachment 214992
  1. Problem cutting circles - arc shifting issue
    By pkuhns in forum DIY CNC Router Table Machines
    Last Post: 08-16-2010, 12:45 AM
  2. Help Cutting circles TM2 router
    By John999 in forum Torchmate
    Last Post: 09-19-2008, 10:41 AM
  3. Cutting arcs and circles
    By inaman in forum GibbsCAM
    Last Post: 04-26-2008, 08:04 PM
  4. Problems cutting circles
    By curtisturner in forum Mach Mill
    Last Post: 08-04-2007, 06:15 AM
  5. Cutting circles and arcs
    By Hack in forum CNC Machine Related Electronics
    Last Post: 11-08-2004, 10:12 PM
