587,875 active members*
3,419 visitors online*
Thread: Programming
    Feb 2012
    Programming
    Hello,
    I am getting an error on this cycle. The error reads no circle radius 022. The g71 starts to run and I believe on its second to last pass it shows this error any help would greatly be appreciated. The error comes up on line G03 x.984 Z-.02 R.4125.
    N10(PROFILE TOOL)
    G50S850
    G0T1010M8
    G96S250M3
    G0G42X1.3Z.1
    /G71P100Q101U.02W.002S200D500F.004R1
    N100W0G0X.825
    G01Z.02F.0015
    G03X.984Z-.2R.4125F.004
    G01Z-.23
    G03X.825Z-.43R.4125F.004
    G01X1.225Z-2.02F.004
    G03X1.00Z-2.420R.550F.004
    G01X1.125F.004
    Z-3.1
    N101G0G40X1.3Z.1
    X5.Z10.
    T1000
    M1
    G0G42X1.4Z.1
    /G70P100Q101
    G1Z.02X.825
    T1000
    M1
    Aug 2011
    2517
    The program ran fine in my simulator software (see pic below)
    However on a real machine this program has several fundamental issues.
    On the G71 line the R1 should not be there.
    Also line N101 should not include tool nose radius compensation cancel or a positive Z value.
    Plus you cancelled the tool offset / geometry then you are using the tool again in G70. That would result is a big crash, usually.
    It should be......
    N10(PROFILE TOOL)
    G50S850
    G0T1010M8
    G96S250M3
    G0G42X1.3Z.1
    /G71P100Q101U.02W.002S200D500F.004 R1 <---- delete this
    N100W0G0X.825
    G01Z.02F.0015
    G01Z-.23
    G01X1.125F.004
    Z-3.1
    N101X1.3
    G0G40X5.Z10.M9
    T1000
    M1
    N20 (FINISH PROFILE)
    G50S850
    G0T1010M8
    G96S250M3
    G0G42X1.3Z.1
    /G70P100Q101
    G1Z.02X.825 <---- delete this line it does nothing
    G0G40X5.Z10.
    T1000M5
    M1
    M30
    etc
  1. Programming for HMC
    By Ashish B in forum Uncategorised CAM Discussion
    Last Post: 08-14-2014, 02:21 AM
  2. getting into CNC programming,
    By tiltoff1 in forum Community Club House
    Last Post: 02-24-2011, 07:18 PM
  3. programming
    By rajanvadakkepat in forum Fanuc
    Last Post: 10-10-2009, 03:22 PM
  4. TL2.... programming
    By LorenzoNH in forum Haas Lathes
    Last Post: 04-13-2008, 06:54 PM
  5. Programming Help??
    By dconder in forum Haas Mills
    Last Post: 10-17-2007, 11:06 AM
